Author Topic: cam sensor  (Read 2570 times)
dazza88
  • luton (bedfordshire)
    • 2001 2.6 v6 auto omega
cam sensor
« on: 24 December 2012, 21:00:43 »
Hi guys
Ive just been going through some of the posts in mantaince post and ive seen a post and pics of him changing his cam sensor on his 2.2 he changed it to get hos omega out of limp mode home im really thinking bout doing mine to see if that helps me instead if ecu but if my sensor was gone would that stop my s and snow botton working many thanks again and sorry to pester you all again. I got it read today by someone who knew how to use it and it it said (mif) transmission module whitch i think it means gearbox ecu plz help
2002 2.2 cd auto             mrk2 astra gte
vauxhall colton               vauxhall omega 2.6 v6 auto
ford sierra saphire 20l   vauxhall omega 2.2 dti 02 plate
dazza88
Re: cam sensor
« Reply #1 on: 24 December 2012, 21:19:04 »
And just wondering if the gearbox is in limp mode would my s and snow botton work anyway??
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: cam sensor
« Reply #2 on: 24 December 2012, 21:32:55 »
The Sport and Ice mode will not work when the car is in limp mode.
The car will act as if it is in Ice mode, pulling away in 3rd gear.
You can however use 1st and 2nd gear by manually selecting them with the gear lever.
dazza88
Re: cam sensor
« Reply #3 on: 24 December 2012, 22:05:47 »
Oh right cool thank you. I can use 2nd gear manually but when i put it in 1st gear it moves for like 2 secs then revs like it has came out of gear or something is telling it to do something.
gibby
  • braintree
Re: cam sensor
« Reply #4 on: 25 December 2012, 19:14:16 »
Merry Xmas hon member, I had the same prob with my 2.2l 2001 z22xe, in most cases it could go in limp mode and for long period I thought it was a gearbox prob. And one of the mechs also confirmed to me that it was the gbox and needed to replace it. But one day as I started off it went in limp mode, I stopped switch off the engine for few seconds and start off again then surprising the limp mode was gone. After that, everytime it went into limp mode I could stop and restart the car and it could come out of limp mode. Sometime later one member instructed me to change the cam sensor, then after changing the cam sensor the prob was gone till now, that was ten month ago. So better think of the cam sensor mate. :y
« Last Edit: 25 December 2012, 19:15:56 by gibby »
dazza88
Re: cam sensor
« Reply #5 on: 25 December 2012, 19:21:49 »
Cheers mate.
Yer i found an old omega site earlyer and that said the same as mine same code number and same thing im gana order one wednesday. But what im worried about is would that maje my first gear work again
gibby
  • braintree
Re: cam sensor
« Reply #6 on: 25 December 2012, 22:43:26 »
Cheers mate.
I'm doble sure the s was affected, whenever mine went into limp mode s could not be engaged, but not sure about the 1st gear, however I could engage the 1st gear manually, thanks mate.
dazza88
Re: cam sensor
« Reply #7 on: 26 December 2012, 10:28:18 »
Oh right thats cool then at least my s and ice mode may work again then im just hopeing it might fix my 1st prob but fingers crossed it does but we will find out this week some time depending how quick vauxhall get the part in stock because i dealt they have it on the shelf.   :y
gibby
  • braintree
Re: cam sensor
« Reply #8 on: 26 December 2012, 17:03:19 »
Ya fingers crossed, as long as its a genuine sensor becoz when I was replacing mine, the one which was there looked very new but was a fake one, so fake sensors really gives problems. Its good that you're buying from the dealer, cheers! Merry Xmas. :y :y
dazza88
Re: cam sensor
« Reply #9 on: 26 December 2012, 21:12:14 »
[/quote]
Thanks mate merry xmas. Yer i was going to get a pattern part but ive read on this site that they cause so many more probs so for a sake of 30 quid more its probably easyer yo buy s gm one. Will keep up to sate how it all goes  :y
Re: cam sensor
« Reply #10 on: 27 December 2012, 11:37:56 »
Have you had a P0340 code thats still there then?
Your symptoms are not Cam Sensor.
