Author Topic: coil pack v6  (Read 1939 times)
scottambrose
coil pack v6
« on: 31 January 2013, 13:01:09 »
when changing my rocker covers i noticed the coil pack on the passenger side had some rust around one the legs at the top. and yesterday i had a random misfire which went when i turned the car off and back on again. its the second time its done this in 4 months and all i get in the code is random misfire for those 3 cylinders. i can get a bosch coil pack for 65 pounds new. are bosch ok and is it likely going to be this at fault?
Re: coil pack v6
« Reply #1 on: 31 January 2013, 19:10:05 »
Probably and Bosch OK :y
manolo
Re: coil pack v6
« Reply #2 on: 31 January 2013, 20:39:11 »
maybe you can borrow from friend to test before you buy?
I still fight with my misfire
http://www.omegaowners.com/forum/index.php?topic=111227.0
scottambrose
Re: coil pack v6
« Reply #3 on: 31 January 2013, 20:42:38 »
The misfire is set iff by hard acceleration and as soon as you turn the engine off and re start its fine
2woody
  • Northumberland
Re: coil pack v6
« Reply #4 on: 31 January 2013, 22:18:37 »
make sure it really is a Bosch one - there are plenty of ebay specials masquerading as Bosch.
Bosch were the OE manufacturer
symes
  • oxford
    • R reg 940 volvo
Re: coil pack v6
« Reply #5 on: 31 January 2013, 23:03:51 »
+1 :y
Re: coil pack v6
« Reply #6 on: 31 January 2013, 23:25:02 »
Thats cheap , i was quoted £90 for the bosch last year .
John-R
  • Liverpool
    • 2003 2.6 V6 CD
Re: coil pack v6
« Reply #7 on: 01 February 2013, 00:28:10 »
If you can get genuine Bosch for that price get them. Usually they are over £100.
I found these on eBay - search for item listing 290576054834.
I got a 2-4-6 in December 2011 and it's lasted so far.
Make sure you seal the scuttle as described elsewhere on OOF - it really does make a difference in stopping the water dripping on the pack and in the plug wells.
You can pick your friends and you can pick your nose . . but you can't pick your friends nose !
scottambrose
Re: coil pack v6
« Reply #8 on: 01 February 2013, 06:51:20 »
I xan order direct from bosch through my work
