low beam fld vision - vectra cdx
Started by mcd840, 06 February 2013, 23:29:33
mcd840
hi all, just wondered how many of you omega owners have had "low beam fld vision" in your check control displays and what it took to correct it ? i have this messgae on my cdx vectra, headlights work fine, the go up and down aswell, however if im parked still at night a can see both lights make adjustments for no reason, im told that this is a generic ecu response and can mean auto leveling has failed, bulb on the way out or ballast on the way out. i checked the levelling sensor on the front wishnbone today and thought i had cracked it but not so sure...the arm that links to the two small ball joints was very loose at one end and i could just slide it right of the ball joint but to be fair it wasnt hanging of in the first place so unsure if this is at fault or not. the rear sensor seems nice and tight. any input appreciated
cheers
Welcome to the forum
A proper code reader will tell you specifically what the car is complaining about. A common fault on an Omega with this fault message, is a faulty front wish bone sensor.
Either faulty wishbone sensors, faulty lift motors, or (as in my case on the Elite Estate), a broken wire in loom between front sensor & lift motor. ;)
And welcome to the forum mate  :y
mcd840
thanks for replys, theres a guy who has tech 2 and is going to plug it in for me for £20. tell me is there someone on here who offers a tech 2 service? its something i come across when googling this issue but the mention of the tech 2 service was on the old omega owners website...
cheers
Yes same rules apply re tech 2.
See the link in my signiature below.
mcd840
Quote from: chrisgixer on 07 February 2013, 11:35:20
ah, thanks, is there anyone does the central scotland area?
henryd
Quote from: mcd840 on 07 February 2013, 11:52:28
Hotel21 is up thataway :y
other rides
Hotel21 is your nearest tech2 owning member on here. As said. :y
mcd840
Quote from: chrisgixer on 07 February 2013, 11:55:11
does anyone know where he is in scotland?
cheers
henryd
Quote from: mcd840 on 07 February 2013, 12:06:53
cheers
Send him a Pm from his profile page :y
http://www.omegaowners.com/forum/index.php?action=profile;u=7
other rides
hotel21
Glenrothes area but work in Cupar.  :y
Quote from: hotel21 on 07 February 2013, 18:56:51
You can do Vectra-B, but not Vectra-C
hotel21
