low beam fld vision - vectra cdx
Started by mcd840, 06 February 2013, 23:29:33
mcd840
had the car plugged into tech 2 earlier and come back with this
B1424 - NOT PRESENT, LOW BEAM SIGNAL VOLTAGE TO LOW
B3410 - FRONT CAR LEVEL SENSOR SIGNAL VOLTAGE OUT OF RANGE
the voltage coming from the front level sensor was only 0.1 volts where the rear level sensor was showing around 2.7 volts. So we are assuming that the front level sensor is at fault.
Quote from: mcd840 on 08 February 2013, 18:33:22
Was the B3410 PRESENT or NOT PRESENT?
I assume the fact you have warning, it was PRESENT, esp given the live data reading.
Check the front sensor hasn't popped off (similar setup to omega, sensor mounted to subframe, with a ball jointed rod connecting to wishbone)
mcd840
#17
Quote from: TheBoy on 09 February 2013, 08:36:46
cant think...it just said front car level sensor signal voltage out of range, it was only showing 0.1 volts though. I have allready checked the sensor, it was all still in one piece
Quote from: mcd840 on 09 February 2013, 10:58:50..... the sensor, it was all still in one piece
So was mine when I had the same message, the sensor was goosed though. A 'new' sensor solved the problem.  :y
mcd840
Hi again all, right we replaced the front wishbone sensor with a new one with fingers crossed it would solve this...Nope! Warning still on the display, got it plugged back in and the original 2 fault codes which pointed to the sensor are gone and now i have this code: B1001 - controller does not calibrate. (leftside)
anyone know what to do next?
cheers.
mcd840
when any of you replaced the level sensor on your omegas did you need to have any programming done?
Quote from: mcd840 on 23 February 2013, 23:06:08
No, just replace sensor and job done :y
mcd840
hmmm, oh well somethings up with the leftside light now, self levelling lights, what a pain in the arse  >:(
mcd840
sorted, car plugged into tech 2 and headlights re callibrated / re programmed, error message now gone.
