possible problem with Bilstein b4
Started by feeutfo, 14 February 2013, 10:05:09
Hmmm... I'll watch this one with interest :-X :-X ::) ::)
Quote from: aaronjb on 14 February 2013, 23:19:08
Fix it with a BFH?
That's plan A. Plan B is fit lsc shocks.
Moneys is on plan A though, as plan b is expensive. ;D
Put the original self levellers back on .. problem solved .. no contact between components and body ......    :)
Quote from: Entwood on 14 February 2013, 23:35:09
Issue is on the front Enty, lsc = lowered sports chassis/face lift mv6 only. ;)
Quote from: chrisgixer on 14 February 2013, 23:37:12
Okies ... thought it was on the one in your sig .. 3.2 ELITE ... :)  (and I thought I'd wind you up  :) )
Quote from: Entwood on 14 February 2013, 23:39:47
oh I see, a remark on sl shocks damping qualities...? ;)
Just replace them with Plod spec shocks and springs :y Totally bombproof, but might ride a touch higher than you're used to ;D
Liner not starting to come adrift?
Quote from: TheBoy on 15 February 2013, 06:15:39
What you doing up? ;D
No, and both sides are the same. Well, I say no. I haven't looked yet. But a quick feel under the wheel arch suggests its all solid.
Something not quite right as there should be a reasonable amount of clearance between the spring cup and liner.
Liner ok?
Top mounts ok?
Too much errr "ballast" on board?  ::)  :-X  ;D
Shitty Lemforder wishbones to long  ;D ;D ;D :y
On a serious note, you dont have the BMW bushes fitted do you?
Quote from: Marks DTM Calib on 15 February 2013, 13:31:37
Good point, but no, poly fronts, lemforder rears. :y
