Author Topic: Shaking violently  (Read 1451 times)
Spacekid2009
  • Manchester
    • Omega 2.2 16v CDC estateB
Shaking violently
« on: 16 February 2013, 10:05:54 »
So my 2.2 estate has been shaking violently on the front end at 70 ish, took it in for balancing, and although at first glance the tyres look brand new, the inside edge, about 2in were completely thread bare.
Is it usual track rod ends or something more serious? It passed an mot last sept with no advisories.
Any ideas?
Re: Shaking violently
« Reply #1 on: 16 February 2013, 10:09:38 »
Omega needs full geometry, not just balancing.  If its worn that fast, its got some serious alignment issues.
Not sure which Wheels in Motion approved places are your way  :-\
« Reply #2 on: 16 February 2013, 10:25:55 »
Can certainly recommend Nigel Langs in Bolton to sort out the alignment issues, and will also tell you if anything needs changing first.
« Reply #3 on: 16 February 2013, 18:12:12 »
Me too :y :y
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #4 on: 16 February 2013, 22:56:04 »
does anyone know of anyone who does full geo in the midlands, mines due after i done a few jobs to it
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
Jukeboxnut
  • West Sussex
    • 2004 2.2 auto CDX estate
« Reply #5 on: 16 February 2013, 23:02:00 »
Sounds like too much negative camber, my old 2.0 estate had this problem when I first bought it.  Managed to correct it using the spirit level and ruler method, bit crude but effective.
« Reply #6 on: 17 February 2013, 01:24:58 »
Any ideas?
As said camber setting is excessive. Now front shocks per chance? See the guides sections on set up and handling. As the car needs checking for faults before set up can be done, and for common sense/economic reasons.  ;)
Oh, and spirit level methods are ok for getting the car to set up without shagging the tyres after suspension work, but that's about all. Get it set correctly for camber, then there's a chance the toe can be set correctly too, as the toe can not be set until the camber is correct.
« Last Edit: 17 February 2013, 01:27:48 by chrisgixer »
