Warm Start
Started by omega3000, 16 February 2013, 17:58:34
Webby the Bear
Quote from: symes on 16 February 2013, 22:00:33
Quote from: EMD on 16 February 2013, 21:59:00
Petrol smell is normal when foot to the floor mate  ;)
As well as the other bits im sure the vac pipes could all do with de-gunking , taking off and blowing out just to make sure of no blockages  :)
+1  :y
fair enough  :y
just cant see the correlation between starting problems when warm and vac pipes. who knows  ::) :D :y
should it smell of fuel when foot to floor? being a pressurised system i'd have thought volume going through would have no bearing on that?
but then i am still learning  ::) ;D
RIP Paul Lovejoy
Not 100% sure but thought if your foot is on gas and no start but pumping that the system floods  :-\ Could be anything causing it , bloody cars  ::) ::) ;D :D
Webby the Bear
Quote from: EMD on 16 February 2013, 22:14:47
god knows mate  ;D ;D ;D
RIP Paul Lovejoy
Gaffers
classic MAF symptoms.
Quote from: Guffer on 16 February 2013, 22:37:17
Will check that  ;) Think its best to just pull everything off it breather wise and rebuild it after a good cleaning , nothing ever simple eh especially when previous owner has just chucked petrol in it and done no servicing  :(
Wonder if its this Temp Sender  ::)
Searching it seems if its knackered it will trick the ECU into thinking its 250 deg and wont start  ::) :-\
Looks like ill be asking swmbo for more pocket money  ::) :(
Guess i could pull the wires off it when it refuses to start and see if it solves the problem ...  ;)
martin42
how much,try gsf alot cheaper anf your 10% off aswell  :y
Quote from: martin42 on 17 February 2013, 20:29:26
Forgot about that , will give them a ring  :y By the way martin it should go faster now , theres 2 ton of grease and dirt on the floor from the de-greased engine bay  :D
martin42
any metal left on the car  ;D ;D ;D ;D
Webby the Bear
sorry i couldnt get over lads but i was swearing lots at this gay megane!!!  >:( >:( >:( >:( halfords dont sell square drive sockets apparently!!!  >:( >:(
i told him to buy a ford  ::)
RIP Paul Lovejoy
martin42
what did you need a square socket for?
Quote from: Webby the Bear on 17 February 2013, 21:13:46
No worries mate , hope you fixed it  :-\
symes
Webby the Bear
yep, sump nut is square drive on these frenchies  >:(
RIP Paul Lovejoy
martin42
local motorfactors,im surprised halfords didnt sell 1 tho,as ive seen them in the stores before
