Warm Start
Started by omega3000, 16 February 2013, 17:58:34
Would faulty HT leads or diss/pack cause a car to struggle to start once warm ( 106 pug ) Its intermittent but always does it when warm ... cold starts no problem at all  :-\
tidla
Idle valve sticks /goes faulty. Some stick hot/closed and wont start from cold, others don't close and allow too much air when warm.
Webby the Bear
when you say struggling to start steve.... are you experiencing no crank/no start.... or crank/no start?
RIP Paul Lovejoy
Quote from: tidla on 16 February 2013, 19:46:43
ICV
Could be a possibility  ;)
Quote from: Webby the Bear on 16 February 2013, 19:48:40
Half crank / no start only when the car is warm from a run , refuses to start till cooled down . Starter motor needs looking at tomorrow to eliminate  ;)
Webby the Bear
worth checking battery voltage, batt connections, fuel and spark in your diagnosis to rule them out as problems imo  :y
RIP Paul Lovejoy
I was thinking maybe duff HT leads as when the engine is cold it starts perfect , after a run when its all hot under the bonnet and heat transfer to HT leads maybe leading to break up  :-\ Will take the ICV out and clean first to see if that makes any difference .
Quote from: Webby the Bear on 16 February 2013, 20:22:38
Its had new plugs , air filter , oil filter an oil . Never checked the ICV and presuming it will be crudded up  ::) Fuel filter could be blocked but i have a new one to put on . Battery terminals need a clean and check , Mite be worth chucking some redex in tank as well and give it a blow out afterwood  :y
Webby the Bear
Quote from: EMD on 16 February 2013, 21:40:18
i'd personally start by getting a meter on the battery.
then whip the 4 ht leads out, connecting them to their spark plugs and earthing them (metal valve cover perhaps?) and crank over... make sure all 4 are giving spark.
then check fuel pump buzzing and relay/fuse good.
RIP Paul Lovejoy
Aye you can hear the fuel pump when you turn the ignition , when the car is hot and try the throttle to the floor it still wont start  >:( smell petrol though ... had to wait ten minutes before it would kick into life again  >:(
Webby the Bear
Quote from: EMD on 16 February 2013, 21:47:26
that would be what i'd focus my attention on mate first :y
is it coming from the engine bay? wheres the fuel filter in the pug?
RIP Paul Lovejoy
Quote from: Webby the Bear on 16 February 2013, 21:49:27
Its atatched to the chassis near the tank , car has become a bit hesitant at times on the run so replacing the fuel filter would be a good place to start  ;)
Webby the Bear
Quote from: EMD on 16 February 2013, 21:52:17
defo. but i would hunt down that smell first  :y
RIP Paul Lovejoy
Petrol smell is normal when foot to the floor mate  ;)
As well as the other bits im sure the vac pipes could all do with de-gunking , taking off and blowing out just to make sure of no blockages  :)
symes
Quote from: EMD on 16 February 2013, 21:59:00
+1  :y
martin42
hmmm going to be a long day 2moro then  ;D ;D
