Warm Start
Started by omega3000, 16 February 2013, 17:58:34
henryd
Quote from: EMD on 18 February 2013, 15:45:13
Quote from: henryd on 18 February 2013, 15:23:08
Quote from: EMD on 18 February 2013, 14:06:57
Quote from: Marks DTM Calib on 18 February 2013, 14:04:55
The signal the crank sensor see's is weakest during cranking (as the engine turns over at less than idel speed).
It is a type of sensor that can give a porrer signal when hot.
So cranking plus a failing sensor equals a very weak signal.  :y
But again, check the CTS resistances as a starting point.
Will do  :y
Steve,what age car and which engine size,should be able to give you the ohms readings for the CTS at various temps :y
1998 1.1 henry  ;)
Cts check at sensor
10 degrees C  3530-4100 ohms
20                2350-2670
30                1585-1790
40                1085-1230
50                  763-857
60                  540-615
80                  292-326
90                  215-245
hope that helps :y
other rides
Pretty standard sensor range then  :y
 >:( I cant find which is the correct sensor , the nearest to the stat housing is a green connection and next to it on the block is another but blue connection .
Scoured the net and some are saying green some saying its the blue to the ECU  >:(
2 pin on the green
3 pin on the blue
Pug forum is useless for an answer so im stuck now as to which goes to ECU  :( :-\
The Bosch setups are usualy a two pin device although some very early ones were three pin. Normaly an aqua/greeen colour and pretty sure the shitroen ones are the same
Quote from: Marks DTM Calib on 18 February 2013, 18:47:42
I have a new Green one and on the box says " engine management coolant temp sensor " But the connection is different to the one on the car  >:( Back to the drawing board .
henryd
Quote from: EMD on 18 February 2013, 19:00:56
I agree with Mark,it's normally the green one,do you know anyone with a scanner that can access the pug,be good to view live readings and look at what the ECU is seeing
other rides
Quote from: henryd on 18 February 2013, 19:10:31
No henry not that i know of  :(
One thing that ive seen on the web is that if the green sensor is disconnected while the car is running , if the throttle rises then the sensor is working  :-\
Tick over seems high so another pointer towards CTS , ive been sent the right sensor but wrong connection  >:(  >:( >:( Apparently the are 16 different CTS's  ::) Another one on its way  ::)
henryd
Quote from: EMD on 19 February 2013, 12:19:06
Gotta love the frogs ;D ;D
other rides
Quote from: henryd on 19 February 2013, 14:25:38
Aye  ;D Only 14 more to try  >:(
Well new sensor is in , stopped and started 2 times when warm and it starts fine  :) Was well worth an hour of swearing with accompanied frost bite  ::)
henryd
Quote from: EMD on 20 February 2013, 15:26:45
Nice one :y :y
other rides
But did you figure out what the yellow ring was for? ;)
Quote from: aaronjb on 20 February 2013, 15:36:18
Err no  ;D There was a similar one on the old one so im presuming its a colour coding thingamygig  :-\
Quote from: EMD on 20 February 2013, 15:40:15
Maybe it's just so you know which one of the 14 different coolant temp sensors you're meant to order.. ;D
