Author Topic: Oh booger.....  (Read 5211 times)
hotel21
  • The Kingdom of Fife
Oh booger.....
« on: 22 February 2013, 20:26:00 »
The trusty steed has been sidelined pretty much for the past couple of months with only the occasional airing to keep things ticking over. Today was one such day.
Got a couple of suspicious little misfire/not happy hiccups on the way home from work and eventually threw the management light on after several flashes.
Car idles like a bag of spanners in a washing machine and quite down on power.
Did the pedal trick when I first got in and got 304. Just confirmed it by plugging the box of tricks.
Not lifted the bonnet yet but it looks like watching the rugby on the telly may get sidelined.
Ho Hum!!   :(
Abiton
Re: Oh booger.....
« Reply #1 on: 22 February 2013, 20:40:51 »
Has it been (kept) out in the weather, or under cover?
Re: Oh booger.....
« Reply #2 on: 22 February 2013, 20:43:59 »
Ho Hum!!   :(
Never do today what you can put off till tomorrow  ::) ::)
Re: Oh booger.....
« Reply #3 on: 22 February 2013, 20:51:46 »
Leaky scuttle? Scuttle foam wet?  ...questions for tomorrow. :)
hotel21
Re: Oh booger.....
« Reply #4 on: 22 February 2013, 20:56:42 »
3.2 so no dispac as such...
hotel21
Re: Oh booger.....
« Reply #5 on: 22 February 2013, 20:58:14 »
Outside, getting best benefit of what the good Lord decides to launch upon it.
hotel21
Re: Oh booger.....
« Reply #6 on: 22 February 2013, 21:01:22 »
Ho Hum!!   :(
Good job I have the Disco for day to day then!   ;D
Re: Oh booger.....
« Reply #7 on: 22 February 2013, 21:04:16 »
 .... getting best benefit of what the good Lord decides to launch upon it.
I remember winters in Fife!! Brrrrrrrrr!  ::) ;D ;D
Re: Oh booger.....
« Reply #8 on: 22 February 2013, 21:10:27 »
Aeye, water lands on pot 6 of pas coil PAC and runs back and forth along until it either evaporates or sinks into the plug wells past the cp seal.
Drivers side favourite is the wiper spindle directly above pot 5.
Just one to look for. :)
Re: Oh booger.....
« Reply #9 on: 22 February 2013, 21:11:12 »
A test with a hose on the screen reveals all. :)
hotel21
Re: Oh booger.....
« Reply #10 on: 22 February 2013, 21:14:17 »
Will have a play tomorrow.
Mebbe.....   :D
Re: Oh booger.....
« Reply #11 on: 23 February 2013, 11:01:26 »
It would be awkward side ;D
Unclip top off wiring tray (its brittle, be careful), remove wiring tray.
Remove oil filler neck, and then put yellow cap directly on cam cover. Stops shite getting in engine.
You may need to undo vac from plenum - no usually necessary.
2 bolts hold CP in place, remove.
Unplug connector at rear of CP.
To remove CP, screw in 2 plenum bolts about 5 turns, and pull up on these bolts.
Refit is reverse...  ...though I never refitted cable tray, so I can change plugs that side in 15mins (remember I have LPG shite in the way as well)
About 30mins, fiddly bit is unclipping cable tray.
Re: Oh booger.....
« Reply #12 on: 23 February 2013, 11:02:36 »
though before you do, what is Long Term Trim, Bank 2 reading? Should be approx 0%
hotel21
Re: Oh booger.....
« Reply #13 on: 23 February 2013, 11:25:59 »
Both trims both banks were 0. Not going to do anything to it this weekend due to the rugby, lack of replacement parts and availability of the disco as the daily driver.
I know, lazy shiyte...     ;D
Re: Oh booger.....
« Reply #14 on: 23 February 2013, 11:37:01 »
Thats no excuse, as you don't know what you need yet ;D
