Author Topic: Lizzie's Computer Repair Procedure  (Read 3577 times)
« on: 08 March 2013, 18:35:36 »
My PC has  over the last week been playing up.  Three times it cut out with the power going off after going into standby. Once it also cut right out whilst working on a piece of written work.
I was not happy, and as most know I have no problems using a computer, but understanding how they work; well forget it!! ::) ::) ::) :P
So my repair procedure to cure my PC problem?  Call an engineer?  No way, it would be as bad as putting my miggy into a dealer for repair! :o :o :o :o
Instead I treated it like a naughty child..................giving the tower three hard smacks!
All working fine now! ;D ;D ;)
martin42
Re: Lizzie's Computer Repair Procedure
« Reply #1 on: 08 March 2013, 18:39:19 »
lmao,failing that use a big hammer  :y
« Reply #2 on: 08 March 2013, 18:40:02 »
Well done LZ, sounds very technical  :y :y.
cleggy
« Reply #3 on: 08 March 2013, 18:40:32 »
That might make me work  ::) :P ::) ;D ;D ;D
« Reply #4 on: 08 March 2013, 18:45:15 »
It is Del. :y :y
I am going to write up a manual; front, middle, and back page will just show a hand with a full description of the angle and mathematical explaination of the "repair procedure" ;D ;D ;D ;)
« Reply #5 on: 08 March 2013, 18:46:00 »
That has been known before, but not on a computer! ;D ;D ;D ;) ;)
« Reply #6 on: 08 March 2013, 18:49:19 »
It is Del. :y :y
 ;D ;D ;D
« Reply #7 on: 08 March 2013, 18:50:12 »
 ;D ;D ;D ;D :y
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #8 on: 08 March 2013, 18:52:58 »
Sounds like the powerpack is going.   :-\
« Reply #9 on: 08 March 2013, 18:55:43 »
Don't spoil it for me! ::) ::) ::) ;D ;D ;D
Is that thing like the DIS pack on the miggy?  Now I can replace that if I knew what it looked like! :D :D :D ;) ;)
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #10 on: 08 March 2013, 19:01:17 »
Yup is is the part that you plug the power lead into and it has a fan unit on it and a shed load of wires coming out, they are reasonably easy to change, if you can do a dis pack on a miggy then it should be a sinch.  ;) :y
« Reply #11 on: 08 March 2013, 19:18:25 »
Thanks Kevin :y :y
If my "repair" doesn't last I'll do that.  Funnily enough the fan has been making loud running noises for two years now, but is now quite! :D :D :D ;)
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #12 on: 08 March 2013, 19:30:44 »
Thanks Kevin :y :y
 Probably full of dust and you giving it a friendly smack has dislodged some.  ;D ;D ;) :y
« Reply #13 on: 08 March 2013, 19:35:31 »
Yep, take it down to the garage, open it up and give it a good blast with an airline to get rid of the dust. :y
« Reply #14 on: 08 March 2013, 19:40:20 »
If the PSU fans noisy Lizzie a short blast of WD40 through back onto shaft usually cures it ;)
Page created in 0.031 seconds with 16 queries.
