Pages: [1] 2 3  All   Go Down
Author Topic: 2.2 to v6 conversion  (Read 7162 times)
rossco
  • Scotland
    • F/L Omega
« on: 14 March 2013, 21:37:30 »
So ive been thinking about replacing my 2.2 engine in my omega with either a 2.5 v6 or a 2.6.  Ives done a few conversions in my time, but never with an omega. So whats involved in changing them, apart from the obvious loom, mounts, ecu etc...
Re: 2.2 to v6 conversion
« Reply #1 on: 14 March 2013, 21:42:29 »
Just buy a V6 ....  ;) ;) ;) far easier in the end.  :y :y :y :y
« Reply #2 on: 14 March 2013, 21:54:47 »
+1..
not worth  all that work..
rossco
  • Scotland
    • F/L Omega
« Reply #3 on: 14 March 2013, 21:59:40 »
I could do that, but not what I asked. I have a v6 engine lying around, just wondering if theres anything else I need.
« Reply #4 on: 14 March 2013, 22:18:09 »
...., but not what I asked.  ......
I know ............ I made a constructive suggestion - just not worth the effort IMHO. Are diffs the same, is your gearbox the same, are all the exhaust hanger mounts there.
  • Auckland
    • Mazda MPV
« Reply #5 on: 14 March 2013, 22:26:03 »
IIRC the backbox is the same for a 2.2 & a 2.6 :-\ so the backbox hangers will be the same. The centre sections hang on a bracket bolted to the gearbox mount so not an issue if the OP has an R25 gearbox (and all the brackets) bolted to the back of his engine......
rossco
  • Scotland
    • F/L Omega
« Reply #6 on: 14 March 2013, 22:26:35 »
Yeah, thats what I'm asking? I'm assuming I could use the 2.2 diff and would just have to change the front half of prop for the v6 box
rossco
  • Scotland
    • F/L Omega
« Reply #7 on: 14 March 2013, 22:28:22 »
Exhausts are the easy bit really, bit of cut and weld would fix it.
« Reply #8 on: 14 March 2013, 22:49:25 »
It's really not worth the hassle, given Omegas are so cheap, why bother? Just buy a V6. What's the reason for the change?
« Reply #9 on: 14 March 2013, 22:59:24 »
when you drop the v6 in and start to have electronic problems , it will be too late to give up..imo..
OmegaAnglesey
« Reply #10 on: 14 March 2013, 23:04:40 »
Why does your original post say 2.5 or 2.6 as in this post you state you have an engine lying around surely you don't have one of each on your front lawn  ??? ;D
But long term i agree with everyone else just buy an Omega with a V6 unless you want a serious project on your hands.  :y
rossco
  • Scotland
    • F/L Omega
« Reply #11 on: 14 March 2013, 23:13:17 »
I have a 2.5 in my unit. A good friend of mine likes his v6 vectras so has a few 2.6s lying around cheap. The 2.2 is too underpowered for drifting and fitting a v6 would cure that. My car also has a long mot and tax, and is a very clean shell which I got for very very cheap so dont see the point of selling to buy a car I know nothing about. Plus buying one thats already a v6 takes all the fun away from it.
rossco
  • Scotland
    • F/L Omega
« Reply #12 on: 14 March 2013, 23:14:57 »
Why would I get electrical problems? id be changing the whole loom and ecu
« Reply #13 on: 14 March 2013, 23:22:49 »
Issues would likely be upsets with other ECU's which communicate.
If yours is an auto - the TCM will have the wrong map and not be happy.
ABS - different unit and config again, eg v6 has TC, 2.2 doesnt
MID - Config will be wrong, easily changeable with tech2, whereas not sure the others are quite so simple.
Could be a fair few grumbles to sort.
rossco
  • Scotland
    • F/L Omega
« Reply #14 on: 14 March 2013, 23:25:44 »
Mines a manual, abs will be getting removed
Pages: [1] 2 3  All   Go Up
