Author Topic: rocker cover gaskets  (Read 2530 times)
sassanach
  • trowbridge
« on: 23 March 2013, 19:08:36 »
im busy at the moment renewing the head gaskets on my tub,the replacement head gasket set is elring,are the included rocker cover gaskets any cop or is it better to fit genuine?
flyer 0712
Re: rocker cover gaskets
« Reply #1 on: 23 March 2013, 19:33:08 »
Always best with gaskets to use genuine and then you will not be replacing them again very soon.. :y
    • 530D M Sport, 330i Coupe
« Reply #2 on: 23 March 2013, 20:22:37 »
I believe it's only the head gaskets that are Elring, the camcover gaskets aren't if I remember correctly.
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #4 on: 24 March 2013, 23:14:07 »
I'm not going to get pulled into the genuine/non genuine argument but I've fitted the Sebring cover gaskets. I don't think it's been long enough yet but no issues so far.
serek
  • huntingdon
    • 3.2 mv6
« Reply #5 on: 24 March 2013, 23:43:06 »
had them fitted to one of my omegas before done on them about 15K with out any leaks
« Reply #6 on: 25 March 2013, 08:37:18 »
My experience of the headgasket kits is as follows:
The headgaskets are genuinely good (often Elring or Payen)
The cam seals are awful (re-use the originals)
The exhaust manifold gaskets are the wrong type (often composite)
The cam cover gaskets are not upto scratch (so I use genuine, have tried LOADS of different types and there the only ones that last reliably every time!)
The dowty seals are often not great
The inlet seals dont fit (but thankfuly the originals will be fine).
You need the O ring for the water transfer pipe (rear of block)
The manifold to front pipe gaskets are usualy ok.
I got to the point where I bought the headgakets and bolts online, the dowty seals and cam cover gaskets from a genuine source, I usualy replace the stat whilst in there which I get online. I also re-seal the oil cooler so used the loctite sealent (which is not pricey from Vx) plus the Vx aluminium O rings (again, not pricey).
As for the comments re 'genuine', the above is based on experience, learning the hard way.....so come back and re-educate me when you have done 10+ and seen them with 50-100K miles on them.
« Reply #7 on: 25 March 2013, 10:20:54 »
When bored, I sometimes try to find a cheaper supplier for the Greiner genuine cam cover gaskets, as they are quite expensive from dealers. Complete waist of time.
Why can't we source these independently from dealers, like the majority of parts..? :-\
The o rings aren't particularly cheap either. :(
