Author Topic: Replacing Rear 1/4 Glass - job done  (Read 1015 times)
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« on: 01 April 2013, 12:54:16 »
Decided to have a go at doing this with the glass from my, now, donor car (x reg) which has sat on the drive for a year
Not as difficult as you might think. Here's how I did it
Door card off
Remove two of door card screw plates
Gently remove the plastic cover
Pull back the outer door rubber
Lower the window and remove the runner bar (hint from taxi al in here )
The original window is part of the rubber seal, so removed the lot
On the donor car to remove the window intact, I gently prised out the rubber seal from the inside of the door. Starting on the lock side at the bottom and around to the top. This did damage the paint on the door so protect it if required.
To fit I placed the glass into the opening and used the same "prising" method used to remove from donor to get the rubber to re-seat in the the door frame. I tapped it home with a small hammer (just like fitting PVC window beads if you've done it)
Refitted the runner, rubber's & card.
All in all took 2hr's including removing from donor not bad really.
HTH
Phil
Re: Replacing Rear 1/4 Glass - job done
« Reply #1 on: 01 April 2013, 14:00:45 »
A couple of hours well spent by the sound of it :y
SIR Philbutt
    • PJB Home Services
« Reply #2 on: 01 April 2013, 19:25:25 »
Yep - been boarded up since before xmas - NEC for the gadget show next week so had to be done couldn't leave it in a car park like that
Thanks for the hint by the way  :y
