Author Topic: crank sensor  (Read 804 times)
theb00g1em4n
  • isle of wight
    • 2002 omega 2.2cdx
crank sensor
« on: 02 May 2013, 10:57:51 »
Hi, can someone please tell me where the crank sensor is located on a 2002 2.2 omega,
i've looked everywhere and just cant see it
thanks in advance
Figureman52
  • Nottingham
    • 2.6 CD Saloon
Re: crank sensor
« Reply #1 on: 02 May 2013, 15:33:31 »
Re: crank sensor
« Reply #2 on: 02 May 2013, 16:55:57 »
To replace:
Remove the heatshield from over the exhaust for easier access. Run your hand down the oil dipstick tube until you meet it's
entry point into the crankcase. About 50mm from the dipstick tube towards the front of the engine, you`ll be able to feel the crank sensor.
Retaining torx bolt is same size as the ones holding the heatshield.
If you find it awkward to access the bolt you can slip the aux belt off & unbolt PAS pump (& possibly AC cond) and move it away for more clearance.
