Pages: 1 [2] 3  All   Go Down
Author Topic: sheared oil sump pan bolt  (Read 4687 times)
SMD
  • London
    • :( nowt
Re: sheared oil sump pan bolt
« Reply #15 on: 06 May 2013, 20:04:36 »
Ok, thanks for clearing that up. Sorry for the noobiness.  :-[
Any idea of the length of the bolt and where I can get similar looking ones? Or better still, you got a couple spare?
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #16 on: 06 May 2013, 20:07:15 »
Machine mart do a decent little kit that got me out of the shit a few ago when a stat cover on my mates focus sheared as I tightened it, 4 different size reverse thread easy outs with the right size drill bits at about £12. Should sort it if it's not too tight
« Reply #17 on: 06 May 2013, 20:09:54 »
the bolts are not hex-they are torx ;) and yes a 8mm socket will fit-however its a number 10 torx ;)
Of course they are ...... it's been a while since I was under the car  ::) ::)
symes
  • oxford
    • R reg 940 volvo
« Reply #18 on: 06 May 2013, 20:10:38 »
mate this is what you need-- m6 bolt 10mm long  hope that helps-i got all parts from inlet trumpets to sump bolt in box's but it;s 2.5 engine not 3.2
SMD
  • London
    • :( nowt
« Reply #19 on: 06 May 2013, 20:13:57 »
Omego, Any links? I got a book here somewhere...I'll have a look
Symes, thanks. But I want to have an odd looking bolt, don't ask why  :-[  are the bolts on the 2.5 sump different?
« Reply #20 on: 06 May 2013, 20:14:24 »
Either way I might try to drill it out next weekend if I can find the courage.
I don't think it'll be very tight. If a bolt is that tight the head shears while removing it, then it 'king tight, but you sheared it putting it in. If you drill it out, be very careful .... tapping size for M6 is 5mm.
Just try to turn it with a small screw driver or pointed scriber before you get the drill out.  :y :y
« Reply #21 on: 06 May 2013, 20:16:02 »
But I want to have an odd looking bolt, don't ask why  ......
You won't see an odd bolt from the top of a bus ......  ::)  ;D ;D ;D
  • Auckland
    • Mazda MPV
« Reply #22 on: 06 May 2013, 20:17:48 »
20 m6 bolts about an inch apart clamp the oil pan in place while the 'glue/sealant' sets.
If it was my car I would gather the parts to fix the bolt next time I took the sump off.
In the meantime I would fill it with oil & drive it.
symes
  • oxford
    • R reg 940 volvo
« Reply #23 on: 06 May 2013, 20:18:11 »
+1 and heli coil kit ts about £10 and has drill bit/tap/all you need ;)
symes
  • oxford
    • R reg 940 volvo
« Reply #24 on: 06 May 2013, 20:20:48 »
if not leaking-leave it be mate till you got new gasket/bolt-TBH that;s what I would do
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #25 on: 06 May 2013, 20:25:36 »
Should do the trick as long as you drill straight!
http://www.machinemart.co.uk/shop/product/details/cht526-12pce-drill-screw-extractor-s
« Reply #26 on: 06 May 2013, 20:35:24 »
See the/my first reply  :y :y :y
symes
  • oxford
    • R reg 940 volvo
« Reply #27 on: 06 May 2013, 20:52:15 »
pm sent mate
SMD
  • London
    • :( nowt
« Reply #28 on: 06 May 2013, 23:03:21 »
Thanks for all the replies.
symes, thanks buddy replied to your PM.
Andies, car is already oiled up and in use but not yet checked if its leaking. Will do this next weekend. I hope it doesnt because I really don't want to do this again. I left the silicone 18 hours to cure and then I disturbed the bolt so it should be ok... but then again it could leak because I disturbed the bolt and the silicone in the process  :-X  I will try Andy Bs suggestion of using a screwdriver to try and turn it. Dont own a scriber, have no idea what one is  ;D  #
Thanks Omego for the link
« Reply #29 on: 06 May 2013, 23:08:39 »
Hardened steel 'pencil' for scratching/scribing lines onto metal  :y :y :y
Pages: 1 [2] 3  All   Go Up
