Trip computer MPG...V.....Actual MPG
Started by Field Marshal Dr. Opti, 07 May 2013, 15:58:22
I've often been dubious about the accuracy of the Omega trip computer, so I decided to run my own test.
It's not 100% accurate, or scientific, but it should come pretty close.
1. Brim Omega until it is physically impossible to add more fuel.
2. Pay at the desk. This is optional for people from Liverpool. ::) ::) ;)
3.Set trip computer to zero.
After 369.6 recorded miles (Lincolnshire to Wales and return) these are the figures from the trip computer.
Distance....369.6 miles
Fuel used....12.3 gallons
Average consumption.....30.0 MPG
Brimming the tank for a second time gave a slightly different set of figures.
Fuel used....58.55 litres or 12.86 gallons
Average consumption.....28.7 MPG.
So, in summary, the trip computer may not be telling the whole truth, but it's not telling too many porkies either. :y :y :y
zirk
Ive always found the MID types to be reasonably accurate when doing a brim to brim in the past, however the NCDC 20XX Ive aways found the mpg readings far too high compared to actual.
Quote from: zirk on 07 May 2013, 16:03:56
Which one does a 53 plate facelift Omega have?
On petrol Omegas, I've always found it to be within 0.5mpg. Makes no odds which display type, if the display is making a difference, it has the wrong config ;)
LPG, its going to be out. Which way depends on LPG nozzle size, pressure, multipliers etc.
TDs, generally accurate to within a couple of mpg when unchipped. When chipped, overeads by a significant margin (as expected, if you know how the maps work)
zirk
Quote from: Mr. Opti on 07 May 2013, 19:36:47
If its your 2.6 MV6 could have either, NCDC20XX will be with Sat Nav, no Sat Nav then it will be the Philips 2006 with MID.
Quote from: zirk on 07 May 2013, 20:11:35
No posh satnav so it must be this one. :y :y
Mr.OmegaMan
#6
Did 196miles trip distance according to computer and apparently averaged 28.7mpg (used 7.2 gallons total) in the 3.2 on twisty hilly roads no motorways or dual carrageways just country roads pretty much... Pretty good i thought that was, Filled up with Shell V-Power Nitro+ petrol.
Quote from: OmegaMan2.2 on 07 May 2013, 23:10:30
That sounds pretty good to me for a 3.2 auto. :y
SMD
Omegaman, did you reset the average consumption before the journey?
Mr.OmegaMan
Quote from: SMD on 09 May 2013, 13:48:13
Ah I didn't, but still only used £50 odd for 200 miles on those type of roads mentioned, Would resetting the computer give better more accurate results ?
henryd
Quote from: OmegaMan2.2 on 09 May 2013, 16:51:25
Yes it would as what you are seeing could be an average over several hundreds or thousands of miles :y
other rides
28mpg is hard from a 3.2 even on a motorway cruise. Best I ever got was 30mpg between the Welsh end of the grotty M4 and Oxford, mostly at 80mph, except for a few miles of frustration.
Mr.OmegaMan
Quote from: henryd on 09 May 2013, 18:51:32
Reset it now... Been roughly 80miles in it today there and back from the MOT and average MPG on similar roads 24mpg although that's driving sensible due to the issues i have with the steering under heavy braking... Shell V-power Nitro+ petrol again i'm going to treat it on that stuff for awhile to help clear it out thats if this expensive petrol does anything at all..
