Author Topic: Rear Wheel Bearing replacement  (Read 16234 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Rear Wheel Bearing replacement
« Reply #30 on: 03 June 2013, 08:30:33 »
I checked the rear wheel bearing on vauxhall. Epc and they are the same part number and when ordered thru dealer I asked if different. And parts manager said there wasn't any difference because I had seen them listed different on interdebt anyway fitted and working great cheers eric
The rear bearings are different between estate and saloon,by about 3mm,so i wont be going to your dealer to get mine.
Could this be why we are seeing more failures,as saloon bearings have been fitted into estates? Discuss.
« Last Edit: 03 June 2013, 08:32:31 by biggriffin »
Hoof'land storeman.
« Reply #31 on: 03 June 2013, 11:05:42 »
Nearly 250k on the original bearings, and still going strong 8)
I dread to think what you lot do to them ;D you might be on to summat though BG :-\
omegapioneer
  • Omagh Northern Ireland
    • 97 2.5td Elite auto
« Reply #32 on: 03 June 2013, 11:22:17 »
well using vauxhalls EPC disc and search the bearing part 90486468 you get the results listed for both saloon and estate cars even for the old superceeded part number was listed as same, and i dont doubt the parts manager in my dealer either since you dont know him you shouldnt be passing judgement, Eric
Vx trade club card holder
« Reply #33 on: 03 June 2013, 11:40:05 »
A computer is only as good as the person who programmed it. Same is true of data :y
I have a printed version of that which says different  ::)
Still, not my car ;D
omegapioneer
« Reply #34 on: 03 June 2013, 11:44:14 »
thought vauxhall would have got it right for their own epc, can you supply the correct part number for the bearing as i have another estate to repair, eric
andyc
  • Norfolk
Thetford. Norfolk
« Reply #36 on: 03 June 2013, 12:35:07 »
Had a rummage and cannot find the sheet of paper :-\
Not wishing to be argumentative, but given the estate bearings are physically longer how can they possibly be the same or be interchangeable :-\
Jimbob bought his bearings from Allgermanparts a while back iirc, and there was a similar debate then.
Can we presume then that Vauxhall no longer supply one bearing, and if that is the case which one is no longer available?
omegapioneer
« Reply #37 on: 03 June 2013, 13:15:37 »
i will check the measurements of the bearing as i have the old casings still here but looking at epc disc it olny lists the one for all variants of omega and when fitting my new bearings there was no spare room in the hub if anything the circlip was tight to get fully inserted back into the groove, as for life expectancy of my bearings before it could be me hauling half a ton of coal in the boot at times as well as the lpg kit and upgraded stereo, cheers eric
biggriffin
« Reply #38 on: 03 June 2013, 14:31:57 »
The last one i changed,on my other estate was ,to a saloon one,that we had. :-X
Hoof'land storeman.
« Reply #39 on: 03 June 2013, 14:41:13 »
Had another look and still can't find the pages I have >:(
One thing I am sure of was that it listed all three bearing dimensions, and off the top of my head, the estate (and Monaro) bearing measurements are:
74x34x48?.
The saloon ones are:
74x34x45?.
They are, as has been suggested by others,  DIFFERENT.
Whoever updated your copy of the EPC has probably bodged it. Seeing as the last Omega was built ten years ago, I am not surprised :-\
« Last Edit: 03 June 2013, 14:44:54 by ex taxi al »
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
other rides
henryd
  • west cornwall
« Reply #41 on: 03 June 2013, 14:51:15 »
« Last Edit: 03 June 2013, 14:53:28 by henryd »
other rides
« Reply #42 on: 03 June 2013, 14:53:55 »
Finally, some sense :y
henryd
  • west cornwall
« Reply #43 on: 03 June 2013, 14:54:57 »
Reply 11 mentions width difference :y
other rides
biggriffin
« Reply #44 on: 03 June 2013, 14:55:27 »
The last one i changed,on my other estate was different to a saloon one,that we had. :-X
Hoof'land storeman.
Page created in 0.027 seconds with 16 queries.
