Author Topic: Rear Wheel Bearing replacement  (Read 16217 times)
twiglet
  • Norwich, Norfolk
« on: 07 May 2013, 16:14:22 »
Is there a how-to for replacement of rear wheel bearings?  If so, I can't find it!  ::)
If not, can someone give me an indication as to where the best place is to get new bearings (ie. GM or pattern), how much I should be paying for them, and also whether this is a job best left to a garage or not?
TIA   :y
Re: Rear Wheel Bearing replacement
« Reply #1 on: 07 May 2013, 16:17:47 »
At least you should have some scaffolding poles about :) ;)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 07 May 2013, 16:28:38 »
TIA   :y
Sassanach is the man to talk too :y :y
other rides
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #3 on: 07 May 2013, 17:59:21 »
TIA   :y
And saloon and Estate are different sizes...
Weds
  • Chatham, Kent
  • My other hobby
« Reply #4 on: 07 May 2013, 18:02:44 »
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #5 on: 07 May 2013, 18:10:58 »
I have done it at home, but it was not easy.  I have a good tool kit including an hydraulic puller and that was not enough on its own to extract the bearing, I had to add a screw type pusher to help and then the bearing just came out with a lot of effort and swearing.  If you do not have good facilities I suggest leaving it to a garage.
« Reply #6 on: 07 May 2013, 18:18:39 »
TIA   :y
Nah .. hes the man to get to do the job ...  amazing to watch !!! Makes a sod of a job very easy as he has his home made tools that I would now consider essential :)
serek
  • huntingdon
    • 3.2 mv6
« Reply #7 on: 07 May 2013, 20:59:57 »
TIA   :y
do yourself then you will know for next time ::)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #8 on: 08 May 2013, 10:26:09 »
Had mr serek help do mine and getting the hub and etc out was easy,the hard part was the bearing case,but a big hammer n chisel and some swear words i didnt now later and it was out. :)
New one went in easy with a tap and block o wood. :y
Remember estate and saloon are different.
Hoof'land storeman.
« Reply #9 on: 08 May 2013, 12:00:18 »
A bead of weld around the outer race makes them practicaly fall out.
Dazzler
  • Haverhill, Suffolk
« Reply #10 on: 08 May 2013, 12:26:14 »
How so Mark? More info please :y
« Reply #11 on: 08 May 2013, 12:59:44 »
Simple, you weld a bead around the inside of the outer race (the bit that gets stuck).
As its inside the hub mount it cant expand, but as it cools it shrinks...
Dazzler
« Reply #12 on: 08 May 2013, 13:41:30 »
Now that's clever :y
serek
  • huntingdon
    • 3.2 mv6
« Reply #13 on: 08 May 2013, 21:49:53 »
some times take longer to take brake disc off, then replace bearing
« Reply #14 on: 09 May 2013, 01:36:33 »
I'd love to know why you all need to change the rear wheel bearings :-\ mine's done 245k and is still on the originals ::) yet reading through the help section, they seem to fail almost as often as wishbone bushes and HBVs ;D
