Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: Rear Wheel Bearing replacement  (Read 16233 times)
Re: Rear Wheel Bearing replacement
« Reply #60 on: 03 June 2013, 16:16:10 »
i checked back in a old trade club book from 07 which lists the saloon as 90510542 and the estate as 90486468  with only reference to it as another size KIT, REPAIR, REAR WHEEL BEARINGS, 39 X 74 X 39MM (NLS.- USE 90510542) must have been updates thru run eric
So clearly, there are two sizes, one saloon, and one estate ::) Searching by part number and/or reg probably only returns info relevant to that part :-\
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #61 on: 03 June 2013, 16:33:15 »
Nope, you've copped the arse because your wrong ::)
Please excuse the member from middle earth(Reading) he trying to hid behind a alarse ::)
Hoof'land storeman.
biggriffin
« Reply #62 on: 03 June 2013, 16:35:51 »
So there we have it me lud. Two different bearings and part number :y
Hoof'land storeman.
« Reply #63 on: 03 June 2013, 16:50:24 »
Don't believe everything you read on tinterweb ;D
Think you'll find him on Fair Isle :y
« Reply #64 on: 03 June 2013, 16:53:58 »
No apology though ::)
biggriffin
« Reply #65 on: 03 June 2013, 17:20:17 »
Won't hold it against him ya honour ;)
Hoof'land storeman.
« Reply #66 on: 03 June 2013, 17:21:35 »
slowboy
  • lode
« Reply #67 on: 03 June 2013, 20:29:52 »
rear wheel bearing in search.read then do it.
omegapioneer
  • Omagh Northern Ireland
    • 97 2.5td Elite auto
« Reply #68 on: 03 June 2013, 22:11:44 »
yeah 2 numbers in old book not a problem for me as i am getting the estate bearing 90486468 wich is still the same but worrying if your getting the wrong bearing, knew i kept the books for something, eric
Vx trade club card holder
« Reply #69 on: 03 June 2013, 22:29:39 »
You're welcome :y
omegapioneer
« Reply #70 on: 03 June 2013, 23:26:13 »
i think i finally have got the correct info from firstline web page it lists saloon as 39ID 74OD 39 wide with  the estate as 37ID 74OD 45Width  so quite a difference, cheers guys, eric :y
slowboy
  • lode
« Reply #71 on: 04 June 2013, 20:54:48 »
closer :y
biggriffin
« Reply #72 on: 08 June 2013, 09:26:28 »
The calibra use's the same rear bearing as the omega estate
90486468.  :)
Hoof'land storeman.
Pages: 1 2 3 4 [5]  All   Go Up
