Author Topic: Fibre Glass Flat Roof leaky issues. Repair ideas?  (Read 3236 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 14 May 2013, 19:31:32 »
Been up there this morning and there are some what looks like hairline cracks in a few places, apart from that seems in good condition.
So any recommendations as a fix, Im thinking alone the lines of a brush on resin or similar, not convinced the normal roof sealent will be any good or stick to it.
Cheers Chris.  :y
« Last Edit: 14 May 2013, 19:37:10 by zirk »
MV6Matt
  • London
    • No car since 2022....
Re: Fibre Glass Flat Roof leaky issues. Repair ideas?
« Reply #1 on: 14 May 2013, 20:27:40 »
Isopon make a range of glassfibre fillers for all sorts of applications; the marine P40 might help you for the roof (with rain, I mean).
Matthew
(thanks Ian)
horsecow
  • Omagh
    • 2.2 dti cdx/3.2 elite
« Reply #2 on: 14 May 2013, 20:31:04 »
There is (or used to be anyway) a brush on resin you can get which will fix that up no problem. I cant remember the name of it as its yrs since I've used it but a decent hardware store should be able to help you out. Put plenty on the cracks and surrounding area's and a few coats of it is a good idea. I've used it before to fix gutters and roofs and it hasn't leaked yet, that was around 7-8 yrs ago.
Drive 'er like yer late for mass!!
zirk
  • Epping Forest
« Reply #3 on: 15 May 2013, 14:12:58 »
Matthew
Thanks Matthew, I'll look into that, Marine Filler, suppose if it floods could always use the roof as a boat.  ;)
zirk
  • Epping Forest
« Reply #4 on: 15 May 2013, 14:14:22 »
Thanks H, I'll see whats out there  ;)
scimmy_man
  • yorkshire
« Reply #5 on: 16 May 2013, 16:02:49 »
the roof must be fairly recent?
get the roofer back, it shouldnt leak.
a small glassfibre kit from halfords will fix it, then overpaint to protct it from sunlight.
zirk
  • Epping Forest
« Reply #6 on: 16 May 2013, 16:11:11 »
Roof was re-done with Fibre Glass about 20 years ago, yeas I was surprised it was Fibre Glass, not sure I need the Kit, sort of thinking a top coat or resin filler or something, but thanks I will look at the Kits but guessing not cheap from Halfrauds, wonder if it will be on there Trade thingy?  ;)
paul.lovejoy
  • Ramsgate Kent
    • wife mad 2.6 cd estate
« Reply #7 on: 16 May 2013, 20:26:08 »
if its a large crack would you not be better of applying matting in a tape form with the resin then over painting
 heres a supplier
http://www.ariba-fibreglass-supplies.co.uk/fibreglass-grp/+Fibreglass+Tape
i thought wickes had started to do this system but cant find it on thier website
paul.lovejoy
  • Ramsgate Kent
« Reply #8 on: 16 May 2013, 20:33:09 »
another site with kits etc, go to downloads it tells you how to repair etc, the also sell fiberglass flakes you can mix with the resin to make a filler
http://www.fibreglassdirect.co.uk/roofing-materials-and-kits/roofing-kits.html
zirk
  • Epping Forest
« Reply #9 on: 16 May 2013, 22:40:38 »
Thanks Paul, that second site you posted looks well usefull :y
zirk
  • Epping Forest
« Reply #10 on: 16 May 2013, 22:44:20 »
In fact looking back there both good, cheers again Paul.  :y
« Last Edit: 16 May 2013, 22:46:30 by zirk »
paul.lovejoy
  • Ramsgate Kent
« Reply #11 on: 16 May 2013, 22:48:36 »
more than welcome, was sure wickes did something but cant find it may have been thinking of jewson , memories not what it used to be but watched a roof being done on a job i was on looked simple enough with all the trims etc available just a bit sticky ;D ;D
zirk
  • Epping Forest
« Reply #12 on: 16 May 2013, 23:08:55 »
Theres a Jewsons 2 miles from me, so I'll pop in and have a natter ;)
« Reply #13 on: 16 May 2013, 23:49:23 »
Didnt know you could get that stuff from wickes , just the jobbie for me bumper with the glass matting  :)
« Reply #14 on: 17 May 2013, 00:18:48 »
