Author Topic: Rear brake pads & shims  (Read 1646 times)
Tiefer
  • Spain
    • 2.6 Elegance
« on: 15 May 2013, 10:33:56 »
Hi,
I've purchased a GM rear brake pads set to replace the old ones, it comes with pins, springs and metal shims. The pads have also glued shims so, should i put something between the pads and the metal shims? Cooper grease, double sided tape?
I've read here that it's recommended putting a bit of this grease between the caliper piston and the pads, in the springs, pins, etc.. but between the pads and the shims?
Thanks in advance
Cheers
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Rear brake pads & shims
« Reply #1 on: 15 May 2013, 10:38:45 »
I always do  :)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 15 May 2013, 11:18:59 »
Clean were the pads sit in the calipers with a wire brush,put copperslip on the back of the pads and a smear along the edges,unless you have dressed the edges(i do both prevents pads sticking), and put dobs of copper slip in holes were pins go,.
Hoof'land storeman.
Tiefer
  • Spain
    • 2.6 Elegance
« Reply #3 on: 15 May 2013, 14:20:25 »
Ok, thanks, i think i have all the parts and tools.. Busy weekend, i'll replace front discs and pads too and i've not done brakes before  :-\
Cheers
Page created in 0.016 seconds with 14 queries.
