Author Topic: Has any one on here tried this  (Read 4879 times)
markspark
  • Bolton
« on: 06 June 2013, 00:42:30 »
Re: Has any one on here tried this
« Reply #1 on: 06 June 2013, 00:53:14 »
No........
markspark
  • Bolton
« Reply #2 on: 06 June 2013, 00:55:53 »
i have my doubts if it will work or not
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
« Reply #3 on: 06 June 2013, 02:56:29 »
I  expect it does work.  You're running up to 6.8V through a device intended for 3.4 or less though, not good for it. Don't do it you only have the one key.
A simpler method is to hold the key to your head, just above your ear, before pressing.  It adds a few feet as demonstated on Top Gear once.  Try it, it does work, no idea why.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #4 on: 06 June 2013, 03:41:10 »
+1 for the head method as dbdb describes, Does add that little bit more distance.. the brain must give off some serious energy will have to tap it to the house electric at the price of electric is at lol ;D
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #5 on: 06 June 2013, 08:02:42 »
+2......often do that....gets quite a bit of extra distance :y
« Reply #6 on: 06 June 2013, 09:20:26 »
The fob on my Merc can open the car from that far away, it's re-locked itself by the time you get to the car! What's the point?
I_want_an_Omega
« Reply #7 on: 06 June 2013, 11:41:59 »
+3 - do it regularly .....
« Reply #8 on: 06 June 2013, 14:00:15 »
« Reply #9 on: 06 June 2013, 14:03:56 »
All doors except the front passenger side open and close on mine when I use the remote.
Any idea what my problem might be?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #10 on: 06 June 2013, 14:07:00 »
Yeh, it doesn't like you  sticking solenoid  ;D
« Reply #11 on: 06 June 2013, 14:18:31 »
.....is that located in the door, Mr Gonads? :y........and is it a ten minute job to fix?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #12 on: 06 June 2013, 14:25:11 »
Part of the latch assembly if I remember correctly and a little more than 10 minutes :-X
other rides
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #13 on: 06 June 2013, 14:41:40 »
Not too bad tbh
Door open
interior door trim off
Peal back the plastic and you will see it  :y
I used white grease on all mine when they started sticking but some prefer copper slip.
Give all movable bits a good coat and try again.
If it still doesn't want to play, check for volts on the plug.
You should get a 12 volt pulse when you hit the button.
If you get volts but it doesn't want to play then i'd suspect the solenoid itself.
Remember to tape up the plastic fully or you will get wind noise  ;)
Give yourself half a hour to do it
« Reply #14 on: 06 June 2013, 21:28:20 »
Penis size pub bragging rights
That said, some Vauxhalls are particularly bad for some reason.
Page created in 0.028 seconds with 20 queries.
