Author Topic: aircon refilling kits?  (Read 6617 times)
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
« on: 06 June 2013, 17:37:15 »
Hi car leaks after about a year with a supposed refill, not worth replacing valve? so was thinking of a cheap option just for a 2 week holiday so baby does not get fried!
any advice?
www.impactcls.co.uk - Flight Case Manufacture
Re: aircon refilling kits?
« Reply #1 on: 06 June 2013, 17:50:03 »
....l, not worth replacing valve?  ....
Each valve is only a couple of quid if it is them that are leaking. Often though, it's the condenser or compressor that leaks.
« Reply #2 on: 06 June 2013, 18:13:00 »
I paid £3.77 for a valve and £50+ vat for 3 x regasses!
1st regas - £50 + vat plus spotted valve wont seal.
They order one from VX...just the valve innards arrive, after vaccing out, refil as it wont fit...no charge.
I ordered the correct screw in valve replacement...£3.77
They vacc'd, changed and regassed....No charge!
I like my garage!
(had seen from service history Big Blue has never kept refrigerant for very long, hopefully she now will)
pauls
  • By the sea minehead
    • Bmw x3
« Reply #3 on: 06 June 2013, 18:19:05 »
Sorry to hijack this Jim have you got the part numbers for the valves  :y
« Reply #4 on: 06 June 2013, 19:08:49 »
The one at the front of my 2002 3.2 is 13277003
The wrong insert (may have been usable at tha back? 3041827
    • 530D M Sport, 330i Coupe
« Reply #5 on: 06 June 2013, 19:13:13 »
I like my garage!
Errr aren't they supposed to fill the system with an inert gas and check for leaks before vacuuming out again and refilling with refridgerent by law?
« Reply #6 on: 06 June 2013, 19:17:05 »
Technically it wasnt leaking once the cap was scewed on....
ted_one
« Reply #7 on: 06 June 2013, 19:23:35 »
Yup....especially Kwick Krap,they are really hot on leaks....just plead the fifth and say that you know nothing about the car as you have just bought it, that way you only get the short lecture about the legality of defective A/C systems  8) PITA ::)
pauls
    • Bmw x3
« Reply #8 on: 06 June 2013, 19:29:40 »
[/quote
Cheers Jim
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #9 on: 06 June 2013, 19:36:34 »
And to answer the op's question, no those top up kits are useless. Refrigerant and pag oil go in in measured amounts that's why places who do aircon buy machines that put in a measured amount for each particular car. Plus it's illegal to fill a leaking system which is one reason for it having to hold a vac for a set period of time before filling. The other way of testing is to pressurise with nitrogen. So I'd say save the price of the refill and go to someone with proper kit for testing and refilling the aircon.
TuBy's new whipping boy.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #10 on: 06 June 2013, 19:59:59 »
If its done properly, it should be
Suck the gas out
Timed vacuum check
Then disinfectant and refrigerant.
The refrigerant is UV reflective so if its been leaking, they should be able to replace any o rings or bits before they refill  :y
If yours is leaking, get your hands on a UV lamp and have a look before you take it  :y
The refills from Halfords are crap imo  ;)
« Reply #11 on: 06 June 2013, 20:05:57 »
Suck the gas out
Timed vacuum check
Never knew that ???
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #12 on: 06 June 2013, 20:11:57 »
Suck the gas out
Timed vacuum check
Never knew that ???
Yup  :y
My old shed failed its vac check last year.
The clever git just grabbed a UV torch, spotted a dodgy o ring, sorted it and filled it all up  :y
Only cost me 40 quid as well  :D
« Reply #13 on: 06 June 2013, 20:12:54 »
Suck the gas out
Timed vacuum check
Never knew that ???
It's only UV reflective when a UV reflective dye is added to the system  ;)  ;)  ;)
« Reply #14 on: 06 June 2013, 20:15:47 »
My "breaker" had dye in the system that was visible to the naked eye. As you can see ;D
Page created in 0.035 seconds with 20 queries.
