Author Topic: Exhaust  (Read 5542 times)
duke101
  • lincoln
    • Omega Estate 2.5 V6
Exhaust
« on: 10 June 2013, 17:54:05 »
Hi, Can anyone advise me if the exhaust from a 1999 V6 2.5 (pre facelift? grill not part of bonnet) from the downpipes backwards will fit a 2001 3.0 V6.  Thanks
Re: Exhaust
« Reply #1 on: 10 June 2013, 17:55:48 »
Assuming both same body type, ie both saloons or estates then yes :)
2001 would be a facelift so the rear tail pipes will sit further back, due to FL's bigger bumpers  :y
duke101
  • lincoln
Re: Exhaust
« Reply #2 on: 10 June 2013, 18:30:08 »
Many thanks...couple of trims will sort it I assume.
Re: Exhaust
« Reply #3 on: 10 June 2013, 18:44:14 »
correct
symes
  • oxford
    • R reg 940 volvo
Re: Exhaust
« Reply #4 on: 10 June 2013, 21:09:29 »
yes but 2.5 only has 1 outlet not 2 as 3.0 has  :y
duke101
  • lincoln
Re: Exhaust
« Reply #5 on: 10 June 2013, 21:28:27 »
does that matter?
Re: Exhaust
« Reply #6 on: 10 June 2013, 21:39:51 »
Cosmetic only :y
Presume you have the exhaust?....
symes
  • oxford
    • R reg 940 volvo
Re: Exhaust
« Reply #7 on: 10 June 2013, 21:42:04 »
find you get better performance from twin pipe-that is why I fit them on my 2.5's  :y
Re: Exhaust
« Reply #8 on: 10 June 2013, 21:59:41 »
Cosmetic only :y
Re: Exhaust
« Reply #9 on: 10 June 2013, 22:02:42 »
No internal difference on the boxes, only cosmetic as others have said. :)
pirate
  • westhumble surrey
    • steinmetz elit estate
Re: Exhaust
« Reply #10 on: 10 June 2013, 22:14:21 »
better still get rid of whole system and build your own full flow . :y
Re: Exhaust
« Reply #11 on: 12 June 2013, 00:53:49 »
Bit loud maybe :-\
chrisgixer
Re: Exhaust
« Reply #12 on: 12 June 2013, 09:59:33 »
And, quite often with stainless systems, they are a bit flat on power. Possibly due to cost savings using a single pipe, instead of the oe twin mid sections perhaps?
Re: Exhaust
« Reply #13 on: 12 June 2013, 10:33:15 »
Not such a big deal if the bore is larger to compensate :-\
chrisgixer
Re: Exhaust
« Reply #14 on: 12 June 2013, 13:02:05 »
Maybe they need two silencer boxes? Dunno, I'm no exhaust expert, but the ones I've encountered on omegas feel low on power and high on noise.
One in particular was very poorly fitted.
I just get the impression the fitters make them to their own convenience. Longlife, powerflow, both the same, lazy arses.
Also;
They can't make the clamp to the cat sections, it seems, so often cut the cats and weld on instead. The system is then specific to that car unless the cats go with them. Which means extra agro of removing cats, and if your 3.2 has no pre cat code you have no idea if your inheriting that problem as well if buying a used stainless hand made system.
Given the relevant costs, agro and life pans of handmade v an Eternal system for example. I'd take the Eternal every time. Even if they don't last as long as gm tc systems.
