Author Topic: Fuel Pipes  (Read 2273 times)
m.ian
Fuel Pipes
« on: 23 June 2013, 13:04:10 »
Can anybody let me know how the fuel pipes are connected where they come into the engine compartment from the OSN wheel arch?
Re: Fuel Pipes
« Reply #1 on: 23 June 2013, 13:19:31 »
they connect to the inlet manifold, under the plenum.
In feed is 19mm, outbound is 17mm i think  :y
Edit, sorry miss understood, fas as I know its a direct feed from the tank? To the inlet?
« Last Edit: 23 June 2013, 13:21:22 by tunnie »
m.ian
Re: Fuel Pipes
« Reply #2 on: 23 June 2013, 13:21:39 »
Thanks I know that, its the other end that I want to know about
Re: Fuel Pipes
« Reply #3 on: 23 June 2013, 13:25:56 »
This was for my LPG, this shows the fuel lines from the tank into the engine bay, its a solid plastic pipe I think, with some heatshield protection at the end.
m.ian
Re: Fuel Pipes
« Reply #4 on: 23 June 2013, 13:58:14 »
so no break/connector where it goes into the engine compartment?
symes
  • oxford
    • R reg 940 volvo
Re: Fuel Pipes
« Reply #5 on: 23 June 2013, 13:58:45 »
no mate
m.ian
Re: Fuel Pipes
« Reply #6 on: 23 June 2013, 14:03:15 »
OK, reason for asking is that where the fuel pipes enter the engine compartment they are showing signs of rust.
what if anything can I do?
Re: Fuel Pipes
« Reply #7 on: 23 June 2013, 14:05:19 »
Fuel lines are plastic  :y
symes
  • oxford
    • R reg 940 volvo
Re: Fuel Pipes
« Reply #8 on: 23 June 2013, 14:07:15 »
???????? the pipes are plastic-with 17mm/19mm nut fittings on end -to connect to fuel rail--there is a alloy heat shield covering them-so rust???? picky--if pos mate :y
m.ian
Re: Fuel Pipes
« Reply #9 on: 23 June 2013, 15:07:17 »
will take picture so you can see what I mean
martin42
Re: Fuel Pipes
« Reply #10 on: 23 June 2013, 15:27:07 »
Are you not getting mixed up with brake lines???
m.ian
Re: Fuel Pipes
« Reply #11 on: 23 June 2013, 15:31:53 »
No, even I am not that bad  :)
Re: Fuel Pipes
« Reply #12 on: 23 June 2013, 16:42:55 »
Theres a join in the pipes approx. under the drivers door. ;)
m.ian
Re: Fuel Pipes
« Reply #13 on: 23 June 2013, 17:27:44 »
As promised
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Fuel Pipes
« Reply #14 on: 23 June 2013, 18:04:52 »
Here it is (tut, tut!):
