Pages: [1] 2 3 4 5 6 7 8 ... 18   Go Down
Author Topic: cam gasket  (Read 60285 times)
bored bigyin54
  • south wales
    • black beast
cam gasket
« on: 03 July 2013, 14:20:59 »
well i wish i never changed the gasket . went for a 20 mile drive today , every time i came to a roundabout and pulled away i get a plume off white smoke come from exhaust . still got power its just annoying :y :y
Re: cam gasket
« Reply #1 on: 03 July 2013, 15:01:54 »
bored bigyin54
  • south wales
    • black beast
Re: cam gasket
« Reply #2 on: 03 July 2013, 15:17:07 »
just took throttle body of oil is getting in so going to check all breathers again :y :y
Re: cam gasket
« Reply #3 on: 03 July 2013, 15:37:27 »
The throttle body full of oil? What part exactly  ???
There is the thin breather pipe from the cam cover, this should be clear. The throttle body itself can get covered in crude but not liquid oil.
Plugs? Using Water?
symes
  • oxford
    • R reg 940 volvo
Re: cam gasket
« Reply #4 on: 03 July 2013, 15:49:26 »
I dont want to be bearer of bad news---but think it could be headgasket :'(
Re: cam gasket
« Reply #5 on: 03 July 2013, 15:56:09 »
is it using coolant though?
bored bigyin54
  • south wales
    • black beast
Re: cam gasket
« Reply #6 on: 03 July 2013, 15:57:28 »
Plugs? Using Water?
no not using water may be the pipe at the back of engine .dont think its head gasket . its not doing it all the time .now and again when i pull off  :y :y
bored bigyin54
  • south wales
    • black beast
Re: cam gasket
« Reply #7 on: 03 July 2013, 16:02:45 »
only done it since we done the cam gasket .and cleaned the breathers wish i haddent touched it no problem before :y :y
symes
  • oxford
    • R reg 940 volvo
Re: cam gasket
« Reply #8 on: 03 July 2013, 16:03:13 »
leak on egr mounting on back of head? maybe
bored bigyin54
  • south wales
    • black beast
Re: cam gasket
« Reply #9 on: 03 July 2013, 16:05:37 »
no water or oil leaking :y
Re: cam gasket
« Reply #10 on: 03 July 2013, 16:25:03 »
White smoke = burning water, aka your engine is a giant kettle  :)
bored bigyin54
  • south wales
    • black beast
Re: cam gasket
« Reply #11 on: 03 July 2013, 16:29:15 »
no smells of oil  :y :y
Re: cam gasket
« Reply #12 on: 03 July 2013, 16:38:24 »
Re: cam gasket
« Reply #13 on: 03 July 2013, 16:57:24 »
Large amounts of white smoke still points to using water, if the smoke has a grey tint to it, more likely oil.
Either way, if you are seeing "plumes" of smoke, its burning a fluid one way or another  ;)
bored bigyin54
  • south wales
    • black beast
Re: cam gasket
« Reply #14 on: 03 July 2013, 17:00:21 »
just cleaned throttle body . and no smoke at all  :-\ :-\ so going to take the pipe off again at back off engine and see tomorrow :y
« Last Edit: 03 July 2013, 17:01:54 by bored bigyin54 »
Pages: [1] 2 3 4 5 6 7 8 ... 18   Go Up
