Author Topic: Omega 2.2 diesel 03 plate running hot  (Read 1972 times)
IGBryant
  • TW19
« on: 14 July 2013, 16:12:40 »
Hi All, a bit of advise required.
I am having an issue where occasionally the red oil light is coming on. This is only after being in traffic, on investigation I have found the following.
1) If I take a feed from battery to either/both fans, fans come on as they should. So ruled out a fan issue.
2) Even when temp gadge reading 90 degrees no fan may be on.
3) Usually full speed fan has kicked in when checking.
4) I am sure the care used to run about 80 degrees.
5) It feels like the large hose pipes have no water in them when you squeeze them. Is this normal ? How do you bleed these beasts ?
6) Could it be the thermostat not fireing on the low setting. If so where is the thermostat ?
7) Temp reading never goes over just past 90 degrees.
8) Water is at normal level in the expansion resiviour.
Any advice would be very welcome.
Ian B
Sam Burton
  • St Neots, Cambridgeshire
  • Just Car Mad Really
    • Many
Re: Omega 2.2 diesel 03 plate running hot
« Reply #1 on: 14 July 2013, 16:39:21 »
Just to be clear you say oil light is on could this not be faulty oil pressure switch like on my old miggy DTi, have low pressure in water hoses is a good thing as long as the header tank has coolent at the correct levels its in good health it's when it has either no coolent or the pipes go tight you should be worried
Sam
Drives: 2015 Vauxhall Cascada Elite 2.0 CDTI Auto, 2006 Vauxhall Vectra 2.8T VXR 'Ex-Police' Build, 2010 Vauxhall Insignia 2.8T VXR Saloon, 2017 Vauxhall Insignia Elite VX Line Sports Tourer 2.0 CDTI Auto
« Reply #2 on: 14 July 2013, 16:46:59 »
Low oil pressure in a high mileage engine when warm/hot is ok as long as the light goes out the instant you touch the throttle :y
IGBryant
  • TW19
« Reply #3 on: 14 July 2013, 16:56:32 »
That is good to hear, it goes out as soon as the throttle is pressed.
Just strange that it suddenly is running this hot. and the fans are not activating at lower temps
martin42
« Reply #4 on: 14 July 2013, 17:01:45 »
Maybe it's because we're having a sunny spell
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #5 on: 14 July 2013, 21:32:48 »
Do the fans switch on when the aircon is working?,they should run then
other rides
    • 530D M Sport, 330i Coupe
« Reply #6 on: 14 July 2013, 21:40:33 »
Oil pressure switch.  :y
IGBryant
  • TW19
« Reply #7 on: 14 July 2013, 22:05:43 »
Not always, although I have noticed if the aircon is on the fans are more likly to run.
« Reply #8 on: 14 July 2013, 22:10:17 »
I should add, this is 99% of the time the reason the Oil light comes on on a DTI. Nothing to do with a worn engine  ;) Change that first (easy) and then worry about the other things. If the temp never goes over 90 then there's not a lot wrong.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #9 on: 14 July 2013, 22:12:18 »
I think it is worth noting that the Oil Pressure Light and the operation of the cooling fans are totally unrelated.  :y
Page created in 0.414 seconds with 16 queries.
