Heat Resistant tape
Started by PhilRich, 22 July 2013, 13:51:12
Can any of you chaps in the know tell me if this stuff would shield the main Injector wiring loom sufficiently from the heat of the Head/Inlet Manifold?
The plastic cable tray was discarded when the car was Lpg'd and at the moment is wrapped in black cotton amalgamation tape, but i've found that the plastic Stag Lpg loom wiring protector covering is going brittle and breaking into sharp edged sections which are cutting into the wiring insulation ???
Many Thanks for any help :y
http://www.ebay.co.uk/itm/50mm-High-Temperature-Heat-Resistant-Kapton-BGA-Tape-Polyimide-/111112032884?pt=LH_DefaultDomain_3&hash=item19decb1274
chrisgixer
Re fit the cable tray, mines still fitted. ...?
Thats kapton tape, we used to sue it on circuit boards for mod wires etc.
Not sure how good it would be in an under bonnet environment
Quote from: chrisgixer on 23 July 2013, 01:46:27
OP has a desmond... whether the tray will fit depends on the installation I guess :-\
Quote from: PhilRich on 22 July 2013, 13:51:12
You sure Al. ::)
Quote from: Albitz on 23 July 2013, 11:00:24
You sure Al. ::)
I thought it was a 4 pot too and it's far easier to bin the cable tray. I just used self amalgamating tape when I taped it up into a loom on the car in the guides ;)
I thought Desmond indicated diesel ?  :-\
Quote from: Albitz on 23 July 2013, 12:57:21
Desmond Tutu - 2.2 Albs ;)
Ah,I see.You learn something every day on here. :y ;D
Thanks for all the replies Chaps, i've double wrapped the loom in pvc insulating tape then wrapped it in thick foil and to finish off re-wrapped it in cotton loom almalgamation tape :D :y
