2442 1/21/09 Headlights (Xenon) when driving abroad - Adjustment in owner's manu
Started by Auto Addict, 26 July 2013, 17:55:17
Auto Addict
2442 1/21/09 Headlights (Xenon) when driving abroad - Adjustment in owner's manual not correct INSIGNIA.
Anyone got any info on this please?
It's a technical bulletin issued by Vx., and we're off to France on Sunday.
I like red cars
henryd
other rides
henryd
other rides
Auto Addict
I like red cars
henryd
other rides
This from VXRonline.com:
Quote:- When I went to frog land I swapped my AFL's to European mode
From memory pull the stalk towards you, then turn the ignition on, and hold until you hear a beep, the afl warning light stays illuminated, when in European mode
No AFL = beam benders
Auto Addict
Quote from: PhilRich on 26 July 2013, 19:33:36
It doesn't work on mine, and I haven't got beam benders.
I like red cars
Field Remedy: 2442 - Body - Subject: Headlights (Xenon) when driving abroad - Adjustment in owner's manual not correct
Field Remedy: 2442
Models: Engines: Option:
Insignia 2009... All Xenon Headlamps
Complaint: Adjustment in owner's manual not correct.
Cause: Wrong description.
Production: New owner's manual is scheduled to be introduced in production as of April 2009.
Remedy:
In case of complaint follow the instruction below:
1. Switch off ignition.
2. Pull headlight flash lever and hold.
3. Switch on ignition.
4. An acoustic signal sounds and control indicator (adaptive forward
lighting) is flashing. Every time when ignition is switched on,
control indicator is flashing about 4 seconds.
FunctionalGroup: N - Electrical Equipment
Complaint Group: 08 - Hard to operate,13 - No/Poor Function
Trouble Code: None
At risk of being wrong ::)
Your car doesn't have Xenons or AFL fitted being an SE...
Adaptive Forward Lighting, including Bi Xenon lamps and headlight washers was/is only standard on the Elite, and at £945 ish as an option on tothers, is unlikely to make an appearance on much else :y
Auto Addict
Quote from: ex taxi al on 27 July 2013, 03:17:49
I think you've hit the nail on the head.
Thanks for everyones replies :y
I like red cars
Auto Addict
Called in at the dealers this morning, they didn't know what to do, so they searched Vx.
Solution when driving abroad (according to Vx), set beam to lowest!
Bearing in mind I will have a caravan in tow, setting to the lowest beam will probably bring the lights up to normal.
Sticking tape onto the lights is not an option, as there are no beam deflectors on the lense.
I like red cars
P135 of the Vectra C manual simply suggests getting the lights adjusted for continentality at 'an approved Vauxhall workshop' ::)
