Cambelt kit. Where do you buy them?
Started by Webby the Bear, 02 August 2013, 21:20:30
Quote from: Webby the Bear on 03 August 2013, 11:48:03
cheers guys. if it comes with only 1 idler is that ok to reuse an idler? or should it defo come with two idlers?
2 idlers plus the tensioner. :y
It is the bearings in the idlers that fail first, so these must be replaced.
Stick to one of the brands I mentioned and the kit will be complete.
This is what you should have :
2 idlers
tensioner
backplate
belt
spacer for the lower idler
mounting bolts
Quote from: Webby the Bear on 02 August 2013, 21:20:30
Hi guys,
Sorry to be a pain as I know this is a question I should know the answer to but a little while ago someone posted up a website where you can put your reg number in and pick a kit.
Mine's due end of August and having a get together with the N.O.O.F branch at symes's and need to get my kit.
could someone post a link? :)
cheers
ps, im not going to replace water pump.... so am I right in thinking that I need belt, tensioner, backing plate and two idlers and that's it? :)
:o :o
Why you not replacing the water pump steve  :-\
henryd
Quote from: Emd on 03 August 2013, 16:56:37
Hi guys,
cheers
:o :o
No point on a V6 if its sound,if it aint broke don't fix it :y
other rides
Quote from: henryd on 03 August 2013, 17:13:22
Hi guys,
cheers
:o :o
Just 4 pots then Henry  :-\
henryd
Quote from: Emd on 03 August 2013, 17:20:40
Hi guys,
cheers
:o :o
Aye,always on a four pot :y
other rides
Webby the Bear
thanks guys. ill prob give buypartsby a call to clarify as don't want to order and then have one missing idler  ::)
steve, I think the consensus was that back in the day when pumps were in the £20 bracket it made sense. I think theyre stupid price now though. and as its not cam belt driven im not too worried  :)
RIP Paul Lovejoy
SandBoy
£121 including w/pump......on eurocarparts
That's not particularily cheap tbh. ;)
Quote from: SandBoy on 04 August 2013, 16:46:12
That`s just the kit not including the waterpump
Got the 4 pot water pump for £26  :y
IMHO, it's not worth replacing the water pump on a V6. They have been of poor quality recently, so the one that's in it will probably be better.
SandBoy
Quote from: RobG on 04 August 2013, 16:52:17
Soz,Ooops.....bought some stuff from Euro....forgot I got mine for 2.2CD (Gates with W/pump) from Parkinsons £110 inc.
