Cambelt kit. Where do you buy them?
Started by Webby the Bear, 02 August 2013, 21:20:30
The Contitech kits from Buypartsby are fine. I have them on both my Omegas. (Note to self, Bullet is way overdue  :-[).
Webby, I know in the past you have used my camlock kit.  I just wanted to say, in case it wasn't obvious, this isn't available at the moment, due to the incident with the garage. Being ali, not a hope in hell of it having survived the heat.
symes
Quote from: TheBoy on 05 August 2013, 17:59:29
no problem matey---he coming over to my mad house---do it here-using my cam kit--cheapo sykes pickavant :D ;D
martin42
I'm sure we wasn't doing cambelt,I'm pretty sure it was a v6 to v8 swap  ;D
symes
got a spare one here ;) its a baby though=3500 :y
martin42
Webby drives like a granny,it would be wasted on him,safer to do cambelt lol
Webby the Bear
Hi guys,
I get paid tomorrow so going to order my belt from buy parts by.
This is the one I want at what seems to be a good price. but it doesn't say whether its a gates or contitech. however the part number starts with CT... does that indicate its a contitech?
also going to get a new aux belt. mine has air con..... are there different sizes for with / without AC?
RIP Paul Lovejoy
chrisgixer
There's a conti tech  water mark on the belt map.
Ac is an extra pulley on the aux run, so non ac will be considerably shorter.
Webby the Bear
Quote from: chrisgixer on 20 August 2013, 08:40:24
:-[ :-[ :-[ I am so dumb at times  :-[ :-[ :-[
thanks mate. will make sure I get correct one  :y
RIP Paul Lovejoy
Thats the one I'm about to order Webby, seeing as mine is a tad overdue ::)
Webby the Bear
Quote from: TheBoy on 20 August 2013, 18:00:11
if it's good enough for you then it's good enough for me  :y
RIP Paul Lovejoy
Webby the Bear
Cambelt kit ordered - £80.something
Aux belt (for cars with A/C) ordered - £19.something
30mm offset ring spanner ordered - £6.15
symes has lock kit.
theres nowt else I need is there? :)
RIP Paul Lovejoy
Nope.  If you do find other issues during stripdown, these can easily be replaced after the event :)
Not doing the water pump while the front end is all stripped?
Some grease to re-grease the aux belt tensioner pulley bearings.
Webby the Bear
Quote from: TheBoy on 21 August 2013, 18:29:02
cheers  :y
no mate. too expensive and mines not broken. if it breaks down shortly after the strip downs easy so not a prob.
thanks for the reminder re the grease!  :y
RIP Paul Lovejoy
