Cambelt kit. Where do you buy them?
Started by Webby the Bear, 02 August 2013, 21:20:30
Webby the Bear
Hi guys,
Sorry to be a pain as I know this is a question I should know the answer to but a little while ago someone posted up a website where you can put your reg number in and pick a kit.
Mine's due end of August and having a get together with the N.O.O.F branch at symes's and need to get my kit.
could someone post a link? :)
cheers
ps, im not going to replace water pump.... so am I right in thinking that I need belt, tensioner, backing plate and two idlers and that's it? :)
RIP Paul Lovejoy
Most well known kits are identical to genuine GM and much cheaper.
Look for SKF, Gates or Contitech kits and try all the usual suspects for the best price. :y
chrisgixer
Quote from: Kevin Wood on 02 August 2013, 21:49:56
Buypartsby
Webby the Bear
that's the one! thanks dbug.
thanks kev and chris. I checked my local factor and they want £138. thought they were cheaper than that  :-\
noof = Northamptonshire OOF ;)
RIP Paul Lovejoy
Quote from: Webby the Bear on 02 August 2013, 21:56:10
Am I a member?  If so what freebies are available?  ;D ;D ;D
Webby the Bear
Quote from: dbug on 02 August 2013, 21:57:42
Living in Northamptonshire and being a member of OOF makes you an automatic member of NOOF. I'll see if we've got any car stickers left  ;D ;D ;D
ok, quick question....
this is one I've found.....
http://www.buypartsby.co.uk/details/VAUXHALL/OMEGA/2.5/2000/__/54/CT990K1/timing-belt-kit/
completely confused by the description.... 1.) why does it list timing bekt x 1 3 times  :-\ amd 2.) it only mentions 1 idler (guide pulley). thought there should be 2  :-\
RIP Paul Lovejoy
Of course  ;) Just need a test ride in the TR4  :P ;D ;)
Webby the Bear
Quote from: Emd on 02 August 2013, 22:27:54
Did I mention the monthly subscription payment due of £1,000?
cheque made payable to steve webb (NOOF Secretary)
RIP Paul Lovejoy
biggriffin
put a wanted ad up somebody might have one that they havn't used, allways worth it "dont ask dont get" :y
Hoof'land storeman.
Istr Zirk was selling one a while back,not sure if he sold it ?  :-\
I_want_an_Omega
Quite a few on ebay for about £90 ......
Webby the Bear
cheers guys. if it comes with only 1 idler is that ok to reuse an idler? or should it defo come with two idlers?
RIP Paul Lovejoy
