Pages: 1 2 [3]  All   Go Down
Author Topic: Oof premises.  (Read 6542 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Oof premises.
« Reply #30 on: 07 August 2013, 16:20:11 »
Mmmmmm, might work if its going to be mobile  :-\
You thinking of starting up a mobile tyre and suspension fitting service Chris with cheep rates for members  :-X :-X ;D
Re: Oof premises.
« Reply #31 on: 07 August 2013, 19:25:17 »
A weekly occurrence for any K series owner, surely? ;D
Oi! Mine only failed once in 116k
Re: Oof premises.
« Reply #32 on: 07 August 2013, 20:44:08 »
That's a lot of miles in a week! ;)
Re: Oof premises.
« Reply #33 on: 07 August 2013, 22:58:14 »
I might know of a Volvo 18t rigid coming up for sale in the not too distant future... I might also know some one who can drive it ::)
There's quite a few of us actually ;)
Re: Oof premises.
« Reply #34 on: 07 August 2013, 23:33:31 »
Indeed there are........ ;) ;)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Oof premises.
« Reply #35 on: 07 August 2013, 23:38:33 »
Stick tracks on it and I can drive it too  ;D ;D
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Oof premises.
« Reply #36 on: 07 August 2013, 23:47:13 »
Sounds like the best solution would be a mobile workshop like my kit car group use for tour support. Mercedes 814 with a ramp inside able to hold a vehicle on the top "deck", so you can work underneath it. Fitted out with electrics, a workbench and tool cabinets, generator, compressor, etc. and a large side awning for extra fettling space.
anyone?
Yeah ... me ... actually ...  :o
I've been given first shout on this:
... when it becomes available just after Newent ... as it just so happens! ;)
And it has the added bonuses of being sleeper-cabbed with the 6-cylinder lump, as opposed to the later 4-cylinder 'EcoPower' DBW motor. :y
Re: Oof premises.
« Reply #37 on: 08 August 2013, 00:43:03 »
I know that :-*
Spent the day pondering the potential of this...
chrisgixer
Re: Oof premises.
« Reply #38 on: 08 August 2013, 00:47:05 »
Oh yes, I knew there was something I'd forgotten.  :-[
Can that second level be made into a lift?
Re: Oof premises.
« Reply #39 on: 08 August 2013, 01:02:19 »
Not without some major surgery :-\ but nothing to say the rear panel can't be replaced with a deep tail lift :y
chrisgixer
Re: Oof premises.
« Reply #40 on: 08 August 2013, 01:06:06 »
Ah, and cut the middle out, ramp style? :)
...although a post type lift is better for suspension work, but then again that doesn't stop wim, with there axle jack that rolls along to lift the wheels. :y
Correction, to lift the car up to clear the wheels. :)
cnj
  • ludgershall
    • 2.2 Manual CD(51 plate)
Re: Oof premises.
« Reply #41 on: 08 August 2013, 05:46:42 »
looking at the trailer and chris's comment about lift, I used to work for a livestock haulier who used parkhouse bodies on the trucks, the upper deck was lifted by cables attached to a hydraulic ram, so my thought is why with all the various engineering skills that we have on here could it not be possible to convert such a thing !!
Re: Oof premises.
« Reply #42 on: 08 August 2013, 08:42:09 »
Now people are building them properly it's a rarity, even on the 8-9K RPM examples that are tuned silly.
Re: Oof premises.
« Reply #43 on: 08 August 2013, 09:20:11 »
What you want is one like this: http://bookatrack.com/-PG?atoner&2181&17676&640&.jpg
Deep tail lift, cars go on the upper deck, workshop below, built in generator.. heck it even has a kitchen sink (no, really!)..
Although come to think of it, you couldn't really work on the cars on the upper deck. D'oh.
Re: Oof premises.
« Reply #44 on: 08 August 2013, 19:35:40 »
As it stands, that trailer has two centreline pillars which pass through the top deck and support the roof. The top deck is welded to those supports, creating a rigid structure. There are ways of getting a car onto the top deck, but as Aaron has observed you could never work on it up there ::)
There are different types of double deck trailers which have a floating floor, but they have limitations to the weight of the top deck and also restricted width due to the lift mechanism :-\
The taillift that Aaron linked to is the kind of thing I had in mind, with the central third removed, allowing easy and height adjustable access to the chassis :y
All food for thought though :y
« Last Edit: 08 August 2013, 19:38:01 by ex taxi al »
Pages: 1 2 [3]  All   Go Up
