Author Topic: Temperature Guage  (Read 3214 times)
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
Temperature Guage
« on: 09 August 2013, 15:33:25 »
My temperature guage goes up to the red when I drive in slow moving traffic and the low water light comes on. When I slowly release the expansion cap, some air comes out and the coolant comes back into the expansion bottle. Have I got a blockage in my radiator, or somewhere else. The water pump and thermostat were replace a few weeks ago.
Re: Temperature Guage
« Reply #1 on: 10 August 2013, 12:12:02 »
Firstly, are the radiator fans coming on?
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« Reply #2 on: 11 August 2013, 09:55:42 »
Yes, once the temp gets to about 97, the fans kick in.
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #3 on: 11 August 2013, 10:19:10 »
Sounds like you have an air lock but could also be a blocked rad as you have suggested.
What engine do you have?
Was this happening before the new water pump and thermostat?
sjc
  • Alloa, Scotland
« Reply #4 on: 11 August 2013, 11:24:41 »
Sorry, I see you have an MV6.
Good to see someone else from Scotland on here  ;)
First thing I'd try is to take it for a run with the expansion bottle cap loose to see if it just needs to be bled.  Alternating the climate temp from HI to LO every few minutes often helps too.  Take a container of 50/50 water and anti-freeze with you incase you end up with low coolant once the air releases.
Same question though about its behaviour before the new pump and stat.
martin42
« Reply #5 on: 11 August 2013, 11:54:58 »
Blocked rad
« Reply #6 on: 11 August 2013, 14:00:23 »
Blocked rad
Aye , i know all too well of the symptoms  ::)
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« Reply #7 on: 11 August 2013, 14:09:21 »
It's a 3.0 V6. Took it on the motorway for 100 miles, no problem temp stayed at 95. As soon as I parked it up and ran on tick over the needle started to climb. I heard the fans start once the temp went over 100 this was follow by the low water warning. I switch the engine off, then restarted it the temp went down to 97, and the expansion bottle filled up. I've bought Holts 2 part rad flush, will put that in once the engine is cold. Update to follow…
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« Reply #8 on: 11 August 2013, 21:49:08 »
I've flushed the radiator and everything seems better. I took it out for a run and the temp stayed under 95, I then left it ticking over on my driveway. It took over ten minutes to get to 97, the fan kicked in and brought it back to 95. Which fans are used for the main cooling. I've noticed there are 2 at the front of the car and one at the back of the radiator. Only the offside front fan came on to cool the radiator, am I right in think both should have come on?
« Reply #9 on: 11 August 2013, 22:25:00 »
.... Only the offside front fan came on to cool the radiator, am I right in think both should have come on?
I think I'm right in saying that the fan single behind the rad will come on when the a/c runs. The two in front of the rad should both come on either slowly or at full speed.
PS You still haven't emailed me  ::) ::) ::)
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« Reply #10 on: 11 August 2013, 22:34:54 »
Hi Andy B,
I've just sent the email, let me know if you don't get it?
« Reply #11 on: 11 August 2013, 23:02:57 »
Hi Andy B,
Hi Andy. Received & replied  :y  :y  :y
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« Reply #12 on: 11 August 2013, 23:10:27 »
Thanks, got it. How do you 'ground' the terminals?
« Reply #13 on: 12 August 2013, 05:45:32 »
Ground is another term for 'earth' (Yes Mark .... I know ::))  or negative of the battery  :y
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« Reply #14 on: 12 August 2013, 13:45:57 »
I'll jumper terminals 4 & 5 before grounding terminals 1 & 2 hopefully this will tell me if the fans are working.
