swirl marks on the paint
Started by cem_devecioglu, 17 August 2013, 21:57:30
Bit of a perfectionist eh cem ;)
Keep up the good work  :y
Quote from: dbug on 26 August 2013, 16:16:50
trying ;D thanks :y
honestly for me there are 2 reasons.. 1st I have got fed up with bodge jobs that shops do.. 2nd I need something to do in my retirement years (if I can live that long but my current health says from job to cemetery ;D ;D ;D )
Quote from: cem on 26 August 2013, 12:03:57
Quote from: Emd on 25 August 2013, 23:18:01
If i had results like that i'd be running my own spray shop  :y
I dont think the car's owners patience will be enough to wait me for I complete the job.. ;D
a single hoods paint job took several steps and days (1 day primer (10-12 layer) ,next day sanding + base color coat (7-8 layer) , next day sanding + final color coat+ clear coat next day sanding and clear coat again, + 3-4 days for sanding & polishing nearly a week in total  ;D :-\   :(
ps: and thats done in 34-35 celcius avg temperature .. in a colder climate multiply the time by 2 :-\
Proper spray booth would have heaters wouldnt it  :-\ Im quite positive that if i had a spray booth i could get really good results . Doing a spray job without is hard with dust and insects sticking to it  >:( >:( >:(
Quote from: Emd on 26 August 2013, 20:38:39
If spraying without a booth, wet down the floor etc to keep dust at a minimum, insects etc can be "polished" out once paint set ;)
Quote from: dbug on 26 August 2013, 20:42:59
I had an excellent finish of top coat then i went back half hour later and 2 small bugs had settled on it plus 2 cat hairs  :'( Cant really wet the floor inside the shed as ive got carpet  ;D
Yep..
after few trials you can .. I learned in the same way.. :) and I have seen many pros still making mistakes when they are not careful like runs, flows etc etc
experiencing and sanding quite a lot of them as I also paint outside ;D
I still have a small wing on the hood which was too deep ;D
Quote from: Emd on 26 August 2013, 21:56:03
soon it will be a painted floor  ;D ;D ;D :y
ps: cat hairs are the least of trouble as they are long , they dont bury deep :)
I hope it will be a garage and half size with painted floor . No oil changes in the snow  :(
Quote from: Emd on 26 August 2013, 22:07:06
after some problems with my lungs (lesson learned) I started using this
its 3m paint mask which is widely used and very effective.. so I recommend it..  :y
