swirl marks on the paint
Started by cem_devecioglu, 17 August 2013, 21:57:30
dad1uk
Quote from: cem on 17 August 2013, 21:57:30
here is the solution which I'm going to buy ;D
http://www.hirdavat.com/Eksantrik-Zimpara-Bosch-GEX-125-150-AVE-Eksantrik-Zimpara-125-150-mm-400-W-.html?mrk=1
http://3mcollision.com/products/abrasives/discs/3m-trizact-performance-sanding-disc-3000-grit-6-inch-01459.html
When I saw this Cem, I thought you had found something to polish the dents out of TB's car ;D ;D
best wishes
Simon.
Quote from: dad1uk on 17 August 2013, 22:23:15
unfortunately dents are beyond my profession :-\
Quote from: cem on 17 August 2013, 22:55:17
EPOXY  :P
dbdb
Quote from: Emd on 18 August 2013, 00:24:54
EPOXY  :P
;D will ned lots to fill ;D :y
Quote from: cem on 18 August 2013, 10:40:09
EPOXY  :P
For big dents use fiberglass matting , covers rust holes like magic too  ;D
Quote from: cem on 21 August 2013, 17:59:30
after some physical search and talking to shops, ordered this one :-\
http://www.lawson-his.co.uk/bosch-gex-150-turbo-150mm-6-professional--p85413
yesterday , package arrived .. it has a big box..  and a bit heavier than I expect..
tested the sanding function with 1500 grid on scratch resistent laquer for some hours..
it erased all previous scratches that I caused by hand ??? :) :)
and later tested polishing function with farecla G3 ..
results are stunning to say the least.. never ever seen any laquer without  swirls ;D
although for the polishing I was not patient enough so after some polishing used my rotary polisher to speed up the job but
really I liked it..  so 230 £ didnt fly out the window ;D
and if you are going to sand and polish whole car with a scratch resistent laquer those machines are a must.. and whatever you do sanding by hand causes scratches and hard to remove with that kind of clearcoat
ps: dont believe in the ad its not quiet ;D
here are the pictures of trials/ tests
brief of whats done
sanding with 1500 grid without dual action (no rotary) - bosch gex 150
then polishing with G3 (rotary only) - hitachi
then polishing with  american eagle (no rotary) -bosch gex 150
final protector not applied
very close picture under sun
and some others
Nice job cem  :y You need more filler on those dents though  ;D Test panel i know  :y
Quote from: Emd on 25 August 2013, 23:10:23
no filler jobbie can fill these ,  trust me ;D :y
If i had results like that i'd be running my own spray shop  :y
Quote from: Emd on 25 August 2013, 23:18:01
I dont think the car's owners patience will be enough to wait me for I complete the job.. ;D
a single hoods paint job took several steps and days (1 day primer (10-12 layer) ,next day sanding + base color coat (7-8 layer) , next day sanding + final color coat+ clear coat next day sanding and clear coat again, + 3-4 days for sanding & polishing nearly a week in total  ;D :-\   :(
ps: and thats done in 34-35 celcius avg temperature .. in a colder climate multiply the time by 2 :-\
