0-60 Omega's
Started by Mr.OmegaMan, 21 August 2013, 21:20:08
Mr.OmegaMan
Here's the videos of the 3.2 won't bother with 2.2s ..
http://www.youtube.com/watch?v=5sx7Bm4hZRA
Hard to tell with the angle but I've got the full hd video on the laptop can just about see when it hits 60..
Probably the 3.2 estate is a little slower than the saloon  :-\
Mr.OmegaMan
Quote from: Mr. Opti on 21 August 2013, 23:26:37
Sixty in about 9.0 seconds for a 2.6 auto.
60-100mph...... add about another 13 seconds.
so 0-100 mph around the 22 second mark. :y
Thats good  :y
Haven't done a 0-100 would need a private road for that  ;)
dbdb
Brochure says 8.5 secs for a 2.5 V6 manual :) :), 10.5 auto :(, 9 manual estate :), 11.5 auto estate :( :( :( :(
I have a 2.6 brochure somewhere, I assume it is faster.
To get that I think you'll have to empty boot, passengers and tank, remove the spare and jack, empty washer resevoir, remove aerial and maybe remove door mirrors,  maybe let the tyres down too. :o
Quote from: Mr.OmegaMan on 21 August 2013, 23:34:38
Thats good  :y
But of course. ::) ::) ::) :)
Mr.OmegaMan
Quote from: dbdb on 21 August 2013, 23:37:38
In snow maybe  ::) ;D
Mr.OmegaMan
Anyone know of any 0-150mph time's (on a private runway or private road)  ?  ;)
Most british car mags test two up, and two ways to average out the effects of wind. They also test with a full tank of petrol which obviously adds significantly to the weight.
Autocar magazine has a full set of 0-60 and 0-100 times in the back. :y
Quote from: Mr.OmegaMan on 21 August 2013, 23:41:27
You might need to ask someone from the York meet......... ;) :-X :-X
dbdb
Quote from: Mr.OmegaMan on 21 August 2013, 23:38:46
::) In fresh snow you might want to increase the pressures, same weight on less surface area - more pressure - more likely to penetrate the snow instead of floating on it.
On a dry surface lowering the pressure will give more grip and crucially a lower tyre diameter so better gearing, at the expense of more rolling resistance which probably won't bother you for the 8.5 seconds. ::)
Brochure says 8.5 secs for a 2.5 V6 manual :) :) , 10.5 auto :( , 9 manual estate :) , 11.5 auto estate :( :( :( :(
8.5 for standard manuall 2.5 with diff 3.7 and 9.5 for auto (auto measuring is unnecessary imo as it realy depends on the autobox condition)..
I can claim mine slightly less than 8.0 secs.. but there were other factors ;D ::)
ps: honestly 8.0 secs is not an hats off timing , even small modified 1.6 hatches with athmospheric engines can do that :(
pps: for manuals you can hardly get the same timing as it depends how fast and correctly shift..
tigers_gonads
I've had sub 8 seconds out of my 3.2 mv6 auto estate.
That is with a full donut tank of lpg, 1/4 tank of petrol and 2 fat barstewards in the front  ;D ;D :y
Don't know about you lads but I find that if I feather the throttle as is hits the auto change point for a split second then slam it back down, you get a quicker and cleaner change without the gearbox asking a 1000 questions before changing up  :-\
Estates are definetly a little slower 0-60 and about 5mph slower top end due to the extra drag around the tailgate  :(
Slower than a Mk1 1.8 MX5 with a fat bloke in it ::)
Quote from: Elite Pete on 22 August 2013, 17:20:37
I keep hearing this rumour. It can't possibly be true, or can it?.... :( :( :'(
.....and anyway, I can't imagine TB in a 'girly' MX5. ::) ::) ::) ::) ;D ;D
Mr.OmegaMan
___________________
Sadly I was witness to said fat bloke beating even some of the best 3.0's and 3.2's on the run way  :)
