0-60 Omega's
Started by Mr.OmegaMan, 21 August 2013, 21:20:08
Mr.OmegaMan
What is your 0-60mph time in your Omega.. Just curious.. So i can compare. ?
Been trying to find out the true 0-60 times on my Omega's... Next best thing to a rolling road, Well more fun anyway's..
These where done in the exact same pieces of road for the 2.2/3.2 flattish.. Both had "Sports" mode engaged...
Had someone make a few video's so i could check on computer.
Did 2 videos with the 2.2 1st 10.0 Seconds roughly 2nd 11.0 seconds so i would say average 10.5 Sec ? .. It's running 235/45/17 not the 16" it should have...
Did 3 videos with the 3.2 1st 7.0 Seconds roughly 2nd 8.0 Seconds 3rd 6.0 Seconds, Average 7.0/7.5 say...
Presuming I've calculated these correctly, I'm pretty pleased with those figures.. Well not the 2.2 so much.   :)
Webby the Bear
Quote from: Mr.OmegaMan on 21 August 2013, 21:20:08
very slow  :y
ive tried to test this out of curiosity.... buggered if I could find a road to actually do it on!
RIP Paul Lovejoy
bigegg
I had a printout from a track day done by the previous owner (?) of my 3.0 mv6 (manual) estate:
7.4
8.8
7.3
7.6
Carpe Incendium
Plod 3.2 manual is sub seven seconds, think standard auto is 7.5-8 :-\
Quote from: Webby the Bear on 21 August 2013, 21:26:17
very slow  :y
A good place that I've found (if it's fairly quiet) is out of the Severn Bridge toll booths.  So if you ever find yourself heading to Wales bear it in mind!  :)  Although I wouldn't do it if it's busy as it can be like wacky races out of there!!  ::)  ;D
Mr.OmegaMan
very slow  :y
Here's a good video of a 2.5 V6 0-60 Auto, Looks like 7.5 Seconds as well  :o
http://www.youtube.com/watch?v=QMU8WYU2Yc0
Think i remember some years ago a member from OOF made this before selling his omega or something ?
for better times , drop everything in the car chairs, bumpers, hood, boot, windows, mirrors, sunroof, lights, ac everythng.. then find the smallest size tyre ;D
seriously its not that easy to measure accurately..  besides if you are huge+overweight find a small driver ;D
ps: and dont test it in very hot weather
Mr.OmegaMan
Quote from: cem on 21 August 2013, 22:32:02
I probably should add then those 0-60 times i got where with x2 people in the car  :y
Don't forget your speedo will over read, so you need to try again, aiming for 65 should suffice, or use the speed on a satnav, if it can keep up :y
Mr.OmegaMan
Quote from: ex taxi al on 21 August 2013, 22:36:39
Got an app on the iPhone that does the GPS speed will give that a go next time, Say cruise at 60mph and see what the GPS speed says..  :y
Suspect it will say 56 when speedo says 60, then increase cruise speed one click at a time until gps speed says 60. Speedo will then be saying 65/66 :y
Mr.OmegaMan
Quote from: ex taxi al on 21 August 2013, 22:53:00
Thinking out loud here, But say one was to drive by the GPS speed and a copper comes up behind and pulls you over for speeding... Ah but don't they have calibrated speedo's like your ex-plod would have which is as accurate as GPS ?
Gps is accurate if it can 'see' the satellite, but can struggle to keep up if driving under trees, near tall buildings or low cloud :y But it is far more accurate than the imaginary number that the speedo says ;D
Calibrated speedos aren't fitted to all Police cars, so Mr Plod has to be quite sure that you are speeding before pulling you over. So a traffic car with calibrated kit will pull you if you are consistently doing 10% over the limit with evidence to prove it, whereas a panda car might pull you at 15+%, and then only to give you a yelling at, as they cannot 'prove' that you were speeding :y
You can be arrested without evidence, ie on suspicion, but can only be charged with actual evidence :y
Back to your earlier question though ::) I suspect the 3.2 auto will be nearer the 8 second mark :y
Mr.OmegaMan
Quote from: ex taxi al on 21 August 2013, 23:17:44
Aye trees, tunnels, buildings etc are the GPS's downfall... Talking about coppers gives me the shivers especially when talking about 0-60 on a public forum  :-X ;D
Not bad 8 Seconds considering age ware and tare 190k, x2 onboard etc... Pretty happy with that  :y
Be interesting to see what Chris gets out of that MV8 when its finished  :o :y
Sixty in about 9.0 seconds for a 2.6 auto.
60-100mph...... add about another 13 seconds.
so 0-100 mph around the 22 second mark. :y
