0-60 Omega's
Started by Mr.OmegaMan, 21 August 2013, 21:20:08
Quote from: Mr. Opti on 22 August 2013, 17:24:43
Quote from: Elite Pete on 22 August 2013, 17:20:37
Slower than a Mk1 1.8 MX5 with a fat bloke in it ::)
I keep hearing this rumour. It can't possibly be true, or can it?.... :( :( :'(
.....and anyway, I can't imagine TB in a 'girly' MX5. ::) ::) ::) ::) ;D ;D
Not him, the good looking fatty ;D
Mr.OmegaMan
Quote from: Elite Pete on 22 August 2013, 17:49:47
Poor quality video  :o 90s mobile camera phone ?  ;D
MX-5 1st place an Omega Estate 2nd place ?
Quote from: Mr.OmegaMan on 21 August 2013, 22:45:04
Quote from: ex taxi al on 21 August 2013, 22:36:39
Don't forget your speedo will over read, so you need to try again, aiming for 65 should suffice, or use the speed on a satnav, if it can keep up :y
Got an app on the iPhone that does the GPS speed will give that a go next time, Say cruise at 60mph and see what the GPS speed says..  :y
It won't be anywhere near good enough.  Thats why proper equipment is expensive.
The trouble with lauch starting an auto on a Yorkshire runway is with an auto, its in the land of the gods how much tyreslip you get - ideally you want just enough to hear, but not enough to fire the TC.
But you can't deny a 120bhp rusty Mk1 MX5 does have a far better power to weight ratio than a clapped out Omega ;D, even if you do look like an Essex hairdresser...
Rods2
Performance Box from Racelogic should be on your list. :y
Costs around £450. :y
.. or do what I did and get a 2nd hand AP22 from ebay for about £40 IIRC. :y
Mr.OmegaMan
Quote from: Kevin Wood on 22 August 2013, 23:34:14
Quote from: Mr. Opti on 22 August 2013, 22:58:46
Are both these devices for measuring the accurate speed ?
Quote from: Mr.OmegaMan on 22 August 2013, 23:37:43
Not really. They measure 0-60 by measuring G from a standing start, and integrating the output from a G sensor to determine how long it's taken the car to get to 60.
Mr.OmegaMan
Quote from: Kevin Wood on 22 August 2013, 23:40:17
Think I'd rather spend the £450 on other areas of the Omega though, But for £40 sounds a handy piece of kit  ;)
dbdb
Do you really need these expensive devices to measure 0-60?  I would think use a gps to find out exactly what 60 is on your speedo (if OCD use two or more GPS's) and a good stopwatch.
You could probably even  work it out with just a stopwatch, a tape measure and some calculus. Though I think you'd need to make quite a few runs :(.
easiest/cheapest method is to find a police friend who have an accurate speed measurement device ;D
Quote from: dbdb on 23 August 2013, 02:49:51
Off the shelf GPS isn't really fast enough. Most only output speed at 1 second intervals, and that can be averaged quite heavily. Of course, a purpose-built device can probably achieve better than this. Some of the Racelogic boxes combine GPS and G measurement to get the best of both worlds. Yes, it's an expensive way to get a figure to brag about down the pub, but they can do a whole lot more than that and, if you're developing a car for competition, I would imagine they are worth their weight in gold.
I seriously doubt you can get an accurate reading from the speedo. As said, they aren't that accurate on a steady-state reading but when the speed is changing rapidly the situation is probably even worse as some are quite heavily damped.
in a desperate moment , find a corner where police waiting and get ready to pay the fine ;D
Mr.OmegaMan
I read somewhere the next fast VW golf the "R" version I think can do 0-62mph in 4.9 seconds that's on par with a LC  :o .. Top end probably will still go to the LC though surely..
