Author Topic: Swimming with a key fob  (Read 3529 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« on: 19 September 2013, 13:53:53 »
We were away last week on holiday in Menorca and had a hire car For the week it was a Chevrolet Cruz very very similar to the insignia saloon
On the last but one day we went to the beach and I went out snorkeling I had been out about half an hour and for some reason felt in my shorts pocket the car key  ::)
So After swimming back in and fearing the worst I opened up the fob expecting it to be full of water and fubared but it was surprisingly dry internally So I left it sat in the sun opened up and expected it not to work when we returned to the car but it was fine  :y It was a three button type with a flip out key as Vx use now
I just wondered if anyone else has got one wet and wether I was just lucky ,it did look as if it had been wet before at some point
taitinson
  • Sunny Cornwall
    • 03 2.6 CDX Estate
Re: Swimming with a key fob
« Reply #1 on: 19 September 2013, 14:07:01 »
Yep, did the same thing with the Mig keys  ::) starts ok but remote for doors doesn't work anymore, learnt to live with it to a certain extent, but does get on ya nerves at times, haven't got the dosh at the moment to get it sorted  :-[
« Reply #2 on: 19 September 2013, 14:50:09 »
The newer design might be a bit more water resistant :-\
Could also be that being a newer key, the seals still work as noone has had cause to dismantle it to change the batteries :-\
« Reply #3 on: 19 September 2013, 14:59:49 »
...., haven't got the dosh at the moment to get it sorted  :-[
A new fob is around the £30/£35 mark & probably about the same again if you need Vauxhall to programme it for you but you might be able to get it programmed at a meet if there's still a Tech II available. You'll need your 'Car Pass' though with the code who ever does it for you.
MR MISTER
« Reply #4 on: 19 September 2013, 15:24:15 »
The chevvy cruise is a fine car, the orlando is the people carrier version and both are on the astra j platform, hence the vx (gm) key fob. If you had looked under the bonnet, you would have found the same ecotech unit as in the astra, zafira, meriva etc.
MR MISTER
« Reply #5 on: 19 September 2013, 15:38:18 »
Chevrolet quoted me £55 for the fob+blade and £100 to program it, I don't have the car pass.
However, the guy in Timpsons cut the blade, supplied the fob and programmed it for £114. He also extracted the PIN without the need for a car pass.
« Reply #6 on: 19 September 2013, 16:00:50 »
They've got cleverer over the years then  :y
taitinson
  • Sunny Cornwall
    • 03 2.6 CDX Estate
« Reply #7 on: 19 September 2013, 16:08:24 »
Cheers Andy, lot less than i was fearing, i think i will have to get it done sooner rather than later, as missus keeps complaining as she drives it more than me.  :y
« Reply #8 on: 19 September 2013, 16:32:28 »
If you're opening the car with the key, what about the alarm?  :-\
MR MISTER
« Reply #9 on: 19 September 2013, 16:34:25 »
The transponder would still be recognised?  :-\
« Reply #10 on: 19 September 2013, 16:42:28 »
Does it not give you X seconds to turn the ignition on :-\
MR MISTER
« Reply #11 on: 19 September 2013, 16:44:58 »
I'm sure I used to open mine with the key sometimes, but I can't be absolutely sure......
About anything these days... ;D
« Reply #12 on: 19 September 2013, 16:45:55 »
Alarm & immobiliser are two different animals  ;)  ;)  ;)
« Reply #13 on: 19 September 2013, 16:46:15 »
Don't think so  :-\
MR MISTER
« Reply #14 on: 19 September 2013, 16:56:36 »
Of course they are. What the hell do I know. ;D
