Author Topic: dash isues  (Read 3296 times)
landstan
  • Norway
    • Opel omega b 2.0 16v
dash isues
« on: 04 October 2013, 03:42:18 »
Hey!
The light in the dash flashing like a disco. And half the side is blue and the other side is white, presumably someone who has changed bulbs and not quite got it right. Anyone know how I get replacement bulbs in dash. how do I get out dashboard
Tempcensor is also unstable bouncing up and down.
Oil lamp blinks all the time
Anybody have a solution to this?
Thanks for any reply ..
Re: dash isues
« Reply #1 on: 04 October 2013, 09:30:33 »
Welcome to the forum
Have a look here on how the dash/clocks are removed. http://www.omegaowners.com/forum/index.php?topic=90618.0  :y
Re: dash isues
« Reply #2 on: 04 October 2013, 15:32:16 »
Dash pops out easily, a few minutes to do.  As said see Andy's link above.
landstan
  • Norway
Re: dash isues
« Reply #3 on: 04 October 2013, 16:22:37 »
Ye did that, but didn't resolve any problem.
Can It be a defect relay ?
Re: dash isues
« Reply #4 on: 04 October 2013, 16:47:38 »
The dash just has normal push-in bulbs in there, I can't see why they would flash
Outside temp display is likely to be a faulty outside temperature sensor ..... it lives on the under edge of the front bumper.
Oil light flashing ..... are you sure that is not because your oil pressure is low?  :-\
Re: dash isues
« Reply #5 on: 04 October 2013, 19:20:56 »
Did you change the bulbs ::)
Keith ABS
  • Maldon Essex
Re: dash isues
« Reply #6 on: 04 October 2013, 20:59:08 »
  Possably fault with the dash light dimmer control. Had that on older cars before
Keith B
landstan
  • Norway
Re: dash isues
« Reply #7 on: 04 October 2013, 21:12:41 »
No, Cause they work, just flash time at time. One of the sides of the dash Is stable at all time.
Re: dash isues
« Reply #8 on: 04 October 2013, 21:16:43 »
Fair dos :y
Try Keiths suggestion and swap the headlight switch, see if that makes any difference :-\
landstan
  • Norway
Re: dash isues
« Reply #9 on: 04 October 2013, 21:23:43 »
It's the rpm and half of the speedometer thats flashes.
not the outside temp i ment, Motor temp, jumps up and down.
Oil pressure and level is fine.
The dim switch work just fine.
Re: dash isues
« Reply #10 on: 04 October 2013, 21:25:49 »
Any evidence of arcing on the contacts behind the cluster, either on the back of the unit, or where it connects to the dashboard loom :-\
Re: dash isues
« Reply #11 on: 05 October 2013, 12:15:48 »
Check the grounding points behind the dash.
  • Auckland
    • Mazda MPV
Re: dash isues
« Reply #12 on: 05 October 2013, 14:22:10 »
Faulty alternator regulator?
I don't know how probable it is but I would check the voltage to reassure myself that a faulty regulator wasn't toasting the electrics.
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: dash isues
« Reply #13 on: 08 October 2013, 16:38:29 »
I had the same issue with the tempreture gauge and found that the temp gauge was faulty, replaced with a gauge found at a scrapper and gauge issue was sorted, but as to dash bulbs it has got to be either faulty bulbs or the dash contacts need to be cleaned with contact cleaner or as the the boy suggested check and clean the earth points behind dashboard.
Jaguar XJ6
