Author Topic: Omega. Officially back together  (Read 10379 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 17 October 2013, 22:19:44 »
Finished at about quarter to 9 tonight. But I can happily report the Mig is all back together.
The cambelt cover gave me a few headaches. The aux belt tensioner was tight against it giving me the impression it had perhaps warped when the belt gave up. So swapped it over for a spare I had in the garage. Aux belt tensioner was spinning nicely. Then found out the PAS pulley was tight against the cover  >:( >:( >:( cos I couldn't get the bottom right cover bolt in........ cos the cover I had was for a pre-FL  ::) ::) ::)
So. back to the original cover and it turns out it wasn't warped.... i'd just got the secondary air injection hose bracket (off the alternator) caught up... moved it and the cover fitted nicely.
my next fight was with the aux belt.....again took ages. til I realised it was caught up on the secondary air injection pipe near the PAS pump  ::) ::) ::) ::) ::)
my next fight was with the secondary air injection pipe itself (can you see a theme here  ::)). had to improvise with some fuel line as I lost the fitting near the PAS pump.
other than that all is good,
before I start her up got to fill up the PAS reservoir as I lost it all for some reason (must have tipped the bottle during strip down) and there are a couple of hose clamps missing. but other than that all good.
martin is kindly popping round Saturday with a battery charger as my battery is down to 11.76v. then we'll see how we did.
Anyway, the reason i'm posting this is to discuss the rebuild in general on the omega.
I think I've realised that ive still got so much to learn. not with the theory... the principles are easy. but mainly with overcoming ohysical problems. like when those lifters got stuck. i'd have been nackered. but martins patience got us through. fairly confident I couldn't have done the B bolt myself. or if I could it would have take ages  ::)
great experience in terms of looking at the omega naked. and good to know I now have fresh seals, gaskets and everything else is new (except cc gaskets).
if it goes bang again ill scrap it and get another one though. hopefully it wont lol
oh and its a good job I decided to go and check the exhaust manifold bolts were tight...... i'd missed one  :o :o :o but theyre all done up and torqued now.
Roll on Saturday  :y
RIP Paul Lovejoy
Re: Omega. Officially back together
« Reply #1 on: 17 October 2013, 22:22:21 »
Well persevered :y
« Reply #2 on: 17 October 2013, 22:26:18 »
Yep,good effort webby. Hope it runs sweet when you fire it up. :y
Webby the Bear
  • Northampton
« Reply #3 on: 17 October 2013, 22:27:03 »
Cheers lads,  :y
RIP Paul Lovejoy
« Reply #4 on: 17 October 2013, 22:29:44 »
Nice one Webby!  8)  :y
« Reply #5 on: 17 October 2013, 22:35:06 »
Well done that Man............ :y :y
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #6 on: 17 October 2013, 22:48:48 »
Well done, not an easy car to work on as I found, when I did my head gaskets.  :y :y :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #7 on: 18 October 2013, 09:31:07 »
Just don't worry when you start it as it'll sound bloody awful untill the tappets pump out :y
other rides
« Reply #8 on: 18 October 2013, 10:46:24 »
Cough 'followers' cough.
The trick to removal/insertion of the followers is to use a valve grinding stick....the suckers on the end work vey well for that.
Interestingly, I fully stripped a follower the other night so now know how to fully disassemble and clean one.
The V6 is actualy a pretty straight forward engine to do headgaskets on in reality, about a days job all in (even with swapping manifolds etc over and cleaning)
Webby the Bear
  • Northampton
« Reply #9 on: 18 October 2013, 12:01:02 »
Two were actually rusted in, Mark. And wouldnt budge. i get them out with magnets usually. once they were out i cleaned up all the debris and used fine emery to go around the bore they sit in. and then recleaned. they went in nicely and came out with ease after that..... front one possibly could have used a little more elbow grease but it came out ok.
As for doing it in a day. That would be impossible for me. it's been off the road for one month and a half and ive dne work in the evenings when i can with martins and tb's help. if i was to take a week off and dedicate 9-5 to it i'd guess at about a week.
RIP Paul Lovejoy
henryd
  • west cornwall
« Reply #10 on: 18 October 2013, 12:10:03 »
Sorry :-[ :-[ ;)
other rides
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #11 on: 18 October 2013, 12:25:38 »
Nice one webby :y
« Reply #12 on: 18 October 2013, 13:25:47 »
Where did the rust come from?
The head is alloy and the follower Hardened steel
Gaffers
« Reply #13 on: 18 October 2013, 15:35:21 »
Your first cylinder head replacement is always your slowest, it gets easier and faster :y
Webby the Bear
  • Northampton
« Reply #14 on: 18 October 2013, 15:47:36 »
Well I presumed it was rust. As we sprayed penetrant oil and it began to move the penetrating oil (we used loads) turned brown so assumed rust  :-\
RIP Paul Lovejoy
