Author Topic: rear wheel bearing  (Read 2148 times)
cnj
  • ludgershall
    • 2.2 Manual CD(51 plate)
rear wheel bearing
« on: 27 October 2013, 11:37:47 »
can anyone advise me as to which one to get. I have the choice of at least two, 1st is from 'all german parts' which is stated to be oem and the second is from euro car parts and is skf, which i've known to be reasonable quality for some years now. if however one of the leaned members on here have experience of either or others I should welcome the input. cj.
Re: rear wheel bearing
« Reply #1 on: 27 October 2013, 12:00:46 »
Can you post the sizes up? Estate and saloon are different :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 27 October 2013, 13:10:30 »
Only use a genuine,oe bearing. If its estate same as a calibra. Vauxhall only seem to list the estate one now.
 i did post the part numbers somewere,with picture of genuine estate one.
Hoof'land storeman.
« Reply #3 on: 27 October 2013, 13:21:40 »
They're the same diameter, but estate ones are 4-6 mm longer ottomh :-\
Incidentally estate ones are the same p/n as Monaro rears :y
Point being Monkfish might stock them :y
biggriffin
« Reply #4 on: 27 October 2013, 13:50:40 »
Estate rear wheel bearing kit part number 90486468.
comes with bearing,circlip,lock tap and nut. ;)
Hoof'land storeman.
cnj
  • ludgershall
« Reply #5 on: 27 October 2013, 15:27:12 »
sorry guys, its a 2.2 petrol 2001 estate !
biggriffin
« Reply #6 on: 27 October 2013, 17:28:53 »
Still same bearing.
estate --90486468
saloon--90510542
« Last Edit: 27 October 2013, 17:34:00 by biggriffin »
Hoof'land storeman.
  • Auckland
    • Mazda MPV
« Reply #7 on: 27 October 2013, 17:37:14 »
Still same bearing.
I think cnj is concerned about quality as well as the correct part number.
I don't think you can go wrong with SKF.
Allgermen are usually good but it worries me when a supplier declares 'OE' rather than giving you the actual name because it gives then wriggle room to send you the first part they can lay their hands on :-\
biggriffin
« Reply #8 on: 27 October 2013, 18:17:37 »
Only ever used genuine. As the price differences between tc and elswere inc p+p is about £10.
Hoof'land storeman.
