Author Topic: Smallest measurement  (Read 1560 times)
STMO123
« on: 30 May 2008, 17:42:54 »
My old drinking buddy reckoned that the smallest measurable distance known to man was 'a wrinkle on a pimple on a gnats left b0ll0ck'. Even smaller, he assured me, than 'a coat of paint'.
Does anyone know different?  ::)
Re: Smallest measurement
« Reply #1 on: 30 May 2008, 17:48:49 »
Deb's will be along soon. ;D ;D ;D
Richie London
  • heathrow
« Reply #2 on: 30 May 2008, 17:50:37 »
 ;D ;D ;D
FRE07962128
« Reply #3 on: 30 May 2008, 17:52:54 »
No it is the size of an atom, a tenth of a millionth of a millimetre across or you can place one million atoms across a fine strand of human hair. :y
The atom also consists of 99.9% of empty space! :o
« Last Edit: 30 May 2008, 17:54:11 by FRE07962128 »
Debs.
« Reply #4 on: 30 May 2008, 17:54:35 »
When Gnat`s-whiskers and Fag-paper empirical quantifications are too crude, I use the Ångström which is a non-SI unit of length that is internationally recognized, equal to 0.1 nanometre or 1×10[ch8722]10 metres. It is sometimes used in expressing the sizes of atoms, lengths of chemical bonds and visible-light spectra, and dimensions of parts of integrated circuits. It is commonly applied in structural biology. It is named after Anders Jonas Ångström.
The ångström is named after the Swedish physicist Anders Jonas Ångström (1814–1874), one of the founders of spectroscopy who is known also for studies of astrophysics, heat transfer, terrestrial magnetism, and the aurora borealis.
In 1868, Ångström created a spectrum chart of solar radiation that expresses the wavelength of electromagnetic radiation in the electromagnetic spectrum in multiples of one ten-millionth of a millimetre, or 1×10[ch8722]10 metres. This unit of length became known as the 'Ångström unit', and later simply as the ångström, Å.
The visual sensitivity of a human being is from about 4,000 ångströms (violet) to 7,000 ångströms (dark red) so the use of the ångström as a unit provided a fair amount of discrimination without resort to fractional units. Because of its closeness to the scale of atomic and molecular structures it also became popular in chemistry and crystallography.
Although intended to correspond to 1×10[ch8722]10 metres, for precise spectral analysis the ångström needed to be defined more accurately than the metre which until 1960 was still defined based on the length of a bar of metal held in Paris. In 1907 the International Astronomical Union defined the international ångström by making the wavelength of the red line of cadmium in air equal to 6438.4696 international ångströms, and this definition was endorsed by the International Bureau of Weights and Measures in 1927. From 1927 to 1960, the ångström remained a secondary unit of length for use in spectroscopy, defined separately from the metre, but in 1960, the metre itself was redefined in spectroscopic terms, thus aligning the ångström as a submultiple of the metre.
Since the ångström is now defined as exactly 1×10[ch8722]10 metres, there are therefore 10,000 ångströms in a micrometre (commonly called a 'micron', abbreviated [ch956]m, of which there are 1 million to a metre), and 10 in a nanometre (1 nm = 1×10[ch8722]9 metres).
Richie London
  • heathrow
« Reply #5 on: 30 May 2008, 17:56:03 »
nice one deb  ;D ;D
richie
« Reply #6 on: 30 May 2008, 17:57:21 »
Yeah, I knew that ::)
« Reply #7 on: 30 May 2008, 17:57:28 »
nice one deb  ;D ;D
richie
See, told you so. ;D ;D ;D ;D
But I forgot about L-Z :-[ :-[ :-[
FRE07962128
« Reply #8 on: 30 May 2008, 18:00:10 »
nice one deb  ;D ;D
richie
Yes, I believe my explanation is a bit simpler to understand! ;D ;D ;D
Debs.
« Reply #9 on: 30 May 2008, 18:03:46 »
 ;D ;D ;D ;D....... :y
sir moanalot
  • fens
« Reply #10 on: 30 May 2008, 18:22:27 »
your all wrong im afraid- its gordon browns compassion for the working man !   beat that...................
FRE07962128
« Reply #11 on: 30 May 2008, 18:24:14 »
Sorry but you are wrong.....it is so small it cannot be measured so cannot be counted! ;D ;D :y
waspy
« Reply #12 on: 30 May 2008, 18:27:13 »
What came after "When"  :-[
HolyCount
« Reply #13 on: 30 May 2008, 18:48:09 »
if an atom is 99.9% empty space, then surely it atom skin is smaller than the atom  :-/
You will probably find that my lone brain cell is somewhat smaller  ::)
STMO123
« Reply #14 on: 30 May 2008, 18:53:25 »
That's Count...up to 0  ;D
