Author Topic: Shocks / central locking  (Read 3095 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« on: 08 November 2013, 16:58:31 »
Finally got around to fitting new SL shocks which all went great following the guide,the old shocks were both quite rusty with one leaking. However as most Mig owners know 1 fault sorted normally means another is not far away. The central locking on the drivers door sometimes works but mostly fails or just moves a little, does this mean motor is dead or is it failing from somewhere central? Any help appreciated thanks
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Re: Shocks / central locking
« Reply #1 on: 08 November 2013, 18:41:17 »
Drivers door solenoid failing :'(
Toledodude1973
  • IPSWICH U.K.
« Reply #2 on: 09 November 2013, 08:46:29 »
Is it fairly easy job and can anyone confirm part number please
« Reply #3 on: 09 November 2013, 13:08:42 »
http://www.omegaowners.com/forum/index.php?topic=90504.0 :y
Over to our man in Bristol for pic/part number...
Toledodude1973
  • IPSWICH U.K.
« Reply #4 on: 09 November 2013, 19:56:10 »
Thanks Al ,Having a 2002 model part no.90493702 from the guide would stll be correct yes? any idea of cost now , was 30/40 back in 2006 ,any tips on fitting would be great thanks
« Reply #5 on: 09 November 2013, 20:40:04 »
I might have one in my shed.Will have a look tomorrow. :y
Toledodude1973
  • IPSWICH U.K.
« Reply #6 on: 10 November 2013, 21:26:13 »
Thanks Albs , seems to be behaving itself again but will let you know if it fails again  :( So please don't look too hard just yet mate, cheers paul
Toledodude1973
  • IPSWICH U.K.
« Reply #7 on: 10 November 2013, 21:27:30 »
Oops forgot to say is that the right part number for a drivers side 2002 motor?
« Reply #8 on: 10 November 2013, 21:30:17 »
Yep
Toledodude1973
  • IPSWICH U.K.
« Reply #9 on: 10 November 2013, 21:33:05 »
Thanks Rob i knew the numbers guru would come up trumps  :y
« Reply #10 on: 10 November 2013, 21:40:04 »
Found two but the part number on both is 90493703 - I presume they are rears then ?
Toledodude1973
  • IPSWICH U.K.
« Reply #11 on: 10 November 2013, 21:42:15 »
Thanks Albs back to Rob for numbers of rears :)thankyou
« Reply #12 on: 10 November 2013, 22:49:29 »
Yep
Toledodude1973
  • IPSWICH U.K.
« Reply #13 on: 13 November 2013, 18:31:15 »
thanks for numbers Rob , i'll go down the GM route any idea of cost anyone?front central locking motor
