Author Topic: Have just changed thermostat; now no heat in cabin  (Read 2112 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 17 November 2013, 16:10:47 »
OE03EWW 3.2 petrol manual saloon
I have just changed the thermostat. On refilling with coolant and starting engine, there is no heat in the cabin. Have set climate controls to HI both sides, but no heat comes out. The vacuum line to HBV is still attached. Do I need to bleed something?
Re: Have just changed thermostat; now no heat in cabin
« Reply #1 on: 17 November 2013, 17:11:18 »
Yep sounds like air - engine running, heater controls set to hi, expansion cap off, burp top hose ;)
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #2 on: 17 November 2013, 18:47:51 »
« Reply #3 on: 17 November 2013, 20:24:28 »
........and all vents open ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 17 November 2013, 20:25:51 »
Thank you gentlemen. I discovered the top hose was cold until I burped it, then it got hot, and so did the cabin.
« Reply #5 on: 17 November 2013, 21:48:37 »
Did similar when flushing matrix, revs with cap off, squeezing pipes, soon hot again :)
