Author Topic: oil fillter change  (Read 2430 times)
mike clark
  • hull eastyorkshire
  • 2.5 v6 cdi
    • omega 2.5v6 cdi
oil fillter change
« on: 20 December 2013, 13:18:54 »
can anyone tell me where I can get 1x Connector, oil  PN  90412159
as guna change it when I  sorry we do crank sensor http://images.omegaowners.com/forum/smf2000/Smileys/oofstd/shocked.gif
Re: oil fillter change
« Reply #1 on: 20 December 2013, 13:33:57 »
Vauxhall only :y
« Reply #2 on: 20 December 2013, 13:38:46 »
Even retail prices, not too bad from a dealer. I usually get a box load of both paper and spin on versions to keep me going. As I need both types, also really helps engines to have regular oil changes  :y
mike clark
  • 2.5 v6 cdi
    • omega 2.5v6 cdi
« Reply #3 on: 20 December 2013, 13:39:55 »
no on ere then or a link
« Reply #4 on: 20 December 2013, 13:49:53 »
 Might get a second hand one from a breaker here but suspect most stay in the engines :-\
Give your local dealer a shout, be easy enough to source with a P/N :y
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #5 on: 20 December 2013, 17:49:24 »
They are cheap enough from the dealer  :y
andyc
  • Norfolk
« Reply #6 on: 21 December 2013, 10:30:49 »
£17.76 inc VAT @ Retail Price
Andy
Thetford. Norfolk
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #7 on: 21 December 2013, 12:08:28 »
am I confused (often happens).... £17 for oil filter ?
RIP Paul Lovejoy
« Reply #8 on: 21 December 2013, 12:42:08 »
The part is the connector used to connect a "spin on" filter to the block ... needed when converting from a "paper element" filter to a "spin on" filter ...
Webby the Bear
  • Northampton
« Reply #9 on: 21 December 2013, 12:46:53 »
haha I knew I'd got it wrong ;)
just out of interest..... if you get an oil filter housing that just spins the whole assembly..... how do you get the two apart?  :-\
RIP Paul Lovejoy
« Reply #10 on: 21 December 2013, 12:50:17 »
Strap wrench on the body to hold it, socket on the lid to remove it.... once the lid is off and the filter element removed you can get a long socket onto the hollow bolt at the bottom of the housing to either tighten .. if keeping, or remove, if changing.
TBH .. if changing and the old housing no longer needed .. a pair of stilsons work better than a strap wrench !!
andyc
  • Norfolk
« Reply #11 on: 21 December 2013, 13:39:03 »
A 1lb Ball Pain Hammer is much more fun  :y
Thetford. Norfolk
Webby the Bear
  • Northampton
« Reply #12 on: 21 December 2013, 13:43:45 »
Awesome! Cheers mate  ;)
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #13 on: 21 December 2013, 13:44:02 »
my fave tool  ;D ;D ;D ;D
RIP Paul Lovejoy
