Author Topic: V6 Omega Cannot start  (Read 2513 times)
DaviesEB
  • Monrovia Liberia
« on: 23 December 2013, 16:50:35 »
Hallo All,
Bought a 3.0 Engine V6 and using it on my 2.5 V6. I have made the switch but engine does not start.
Can anyone be of help please.
Darth need your assistance please.
Cheers
Bright
Used Opel Kadett 1.6 and refurbishing Opel Rekord 2.0
Re: V6 Omega Cannot start
« Reply #1 on: 23 December 2013, 16:52:45 »
What car did the engine come from? Probably an immobiliser issue... :-\
« Reply #2 on: 23 December 2013, 16:54:30 »
Hallo All,
Cheers
Bright
Does the EML flash constantly and rapidly whilst you try and start it ?
DaviesEB
  • Monrovia Liberia
« Reply #3 on: 23 December 2013, 17:05:52 »
Yes the Engine i bought was a 3.0 and mine was a 2.5 I am sure you are correct it has to do with the immobiliser.
What can you advice? I am in serach of Darth as i got the 3.0 from him
Cheers
Bright
« Reply #4 on: 23 December 2013, 17:12:18 »
you need the other "bits" to go with the engine, and change them to yours ... IIRC  its the immobilisor ring around the ignition key, the chip in the ignition key, and the ECU ...   someone who knows better will correct me I'm sure .. :)
« Reply #5 on: 23 December 2013, 17:15:00 »
Have you tried it with the 2.5 ecu :-\
DaviesEB
  • Monrovia Liberia
« Reply #6 on: 23 December 2013, 17:17:54 »
Yes i am trying it with the 2.5V6 ECU. Do i have to change same. Darth told me it was just a plug and play thing.
Else can anyone be of help to get him linked up.
Bright
DaviesEB
  • Monrovia Liberia
« Reply #7 on: 23 December 2013, 17:19:06 »
I will have to get back with the Mechanic and revert to you again. let me get some more info from him.
Cheers
Bright
« Reply #8 on: 23 December 2013, 17:22:47 »
Bright
If you're using your original key, then the 2.5 ECU should work :-\
Try this... http://www.omegaowners.com/forum/index.php?topic=90581.0
And report back with the codes :y
DaviesEB
  • Monrovia Liberia
« Reply #9 on: 23 December 2013, 17:23:37 »
Thanks will try the paperclip tst.
Cheers
Thanks
Bright
