Author Topic: help!!!!  (Read 3241 times)
mick1966
  • sheffield
    • omega 2.5 diesel
help!!!!
« on: 30 December 2013, 17:07:22 »
i jump started another car with my omega 2.5 diesel car was running before now it wont start no glow pug light comin and seems no diesel getting in I been told it could be a relay but im lost there that many or any other ideas to solve the problem
Re: help!!!!
« Reply #1 on: 30 December 2013, 19:53:15 »
Start with checking all the fuses (cabin, relay box and if post 1998, the main fuses above battery)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: help!!!!
« Reply #2 on: 30 December 2013, 20:29:15 »
Would fuses blow if you hooked the leads/terminals up the wrong way? Or would that just be instant 'BANG'?
RIP Paul Lovejoy
M Kerr
  • Birmingham
    • 2.5 GLS Omega, X Type
Re: help!!!!
« Reply #3 on: 30 December 2013, 20:41:58 »
Back some time ago in the dark... I connected the leads the wrongway (crossed over).  there was a bit of a fizzing sound and the leads are inclined to get fried (a bit) but I didn't suffer any other issues.
If you managed to get the other engine started the leads weren't the wrong way round...
I'd go for fuses first.
Martin
mick1966
  • sheffield
    • omega 2.5 diesel
Re: help!!!!
« Reply #4 on: 31 December 2013, 12:38:32 »
all fuses checked all ok is there a relay and if so which one my car is s reg
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: help!!!!
« Reply #5 on: 31 December 2013, 14:15:33 »
Any power to the panel at all? Is the starter motor turning? If so are the battery connections getting hot?
mick1966
  • sheffield
    • omega 2.5 diesel
Re: help!!!!
« Reply #6 on: 31 December 2013, 14:52:12 »
car turns over fine just wont fire up no diesel getting through or glow plug light
Shackeng
  • Ramsbury
Re: help!!!!
« Reply #7 on: 31 December 2013, 16:08:00 »
I'm no expert on these, but I believe that the GloPlugs and fuel pump/injectors require correct ECU input, so if all the relays and fuses are OK perhaps you have an ECU problem. :-\
mick1966
  • sheffield
    • omega 2.5 diesel
Re: help!!!!
« Reply #8 on: 01 January 2014, 17:31:32 »
which is the relay to check anyone know
Re: help!!!!
« Reply #9 on: 01 January 2014, 17:37:38 »
I don't have a TD wiring diagram to hand, but not aware of a single relay that could be responsible for glow plugs and no fuel getting through. Simulataneous multiple relay failure is a bit unlikely.
You say no fuses have blown since jumpstarting another car.
Are other electrical systems working as expected? Is the engine management light coming on with the ignition?
Re: help!!!!
« Reply #10 on: 01 January 2014, 17:38:39 »
mick1966
  • sheffield
    • omega 2.5 diesel
Re: help!!!!
« Reply #11 on: 01 January 2014, 18:01:00 »
every other thing workin ok apart from no glow plug light and no diesel getting through
mick1966
  • sheffield
    • omega 2.5 diesel
Re: help!!!!
« Reply #12 on: 01 January 2014, 18:06:10 »
no management light comes on when ignition turned on but all other lights come on ok
M Kerr
  • Birmingham
Re: help!!!!
« Reply #13 on: 05 January 2014, 01:18:39 »
Did you get this sorted Mick?
No EML sounds like there could be no power getting to the ECU (?)  This would prevent both diesel and glow plug.  How do you know there's no diesel coming through (just to check).
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: help!!!!
« Reply #14 on: 05 January 2014, 07:54:18 »
If you have a hiccough in the ECU, sometimes you can reset it by disconnecting the battery completely for an hour or two. Then reconnect, cross fingers and the Omega gods may be with you.....
Ron.
